3369
Регистрация: 04.01.2013 Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
Hello guys, RC40 arrived few days ago.. here is my impressions and pictures
official Description RC40 features our exclusive RAPID SCAN BEAM to deliver an excellent combination of throw and overall coverage. A stunning 3500-lumen output is transformed into a 710-meter throw for long range identification and a 90 degree wide beam for maximum close-range coverage. Combined with advanced power solutions which enable extended periods of runtime for long-running task lighting, RC40 is THE CHOICE for field operations and more. Features · Uses Cree XM-L (U2) LED with a lifespan of 50000 hours · Tailored 7800mAh / 7.4V rechargeable Li-ion battery · 299mm (Length) x 54mm (Battery Tube Diameter) x 108mm(Head Diameter) · 1310-gram weight (including the battery) · Digitally regulated output maintains constant brightness · Anti-roll, slip-resistant body design · Dual switch on the head for fast and convenient operation · Made of durable aircraft-grade aluminum · Premium Type III hard-anodized anti-abrasive finish · Toughened ultra-clear glass lens with anti-reflective coating · Included accessories allow reliable 100V~240V AC and 12V car charging Main specs LED type: 4*Cree XM-L U2 led Output/Runtime: 35lm (160h), 150lm (50h), 550lm (15h), 1500lm (5h), 3500lm (1.5h), Strobe (3500lm) (ANSI FL1) Peak Beam Intensity: 126.000cd (ANSI FL1) Distance: 710m (max) (ANSI FL1) Impact resistant: 1m Waterproof: IPX-8 (underwater 2m) Size: 299mm (length), 54mm (diameter), 108mm (head) Weight: 1310g (including battery) My impressions, Pros + Nice packing + High quality machining, very solid construction + Perfect anodizing, no scratch etc + Perfectly centered leds + Clean reflector, lens surface, no dust etc, + Nice cool white tint (not yellowish, greenish tint) + Very good beam quality (no rings) + Powerful long throw with huge spill + Well lubricated threads, o-ring + The modes are well spaced (35lm, 150lm, 550lm, 1500lm, 3500lm) + Hidden strobe mode + No pwm or other irritating flickering etc + No buzzing sound + Battery indicator + Large heatsinks on head + 12V car charger adapter + Stunning performance (3500lm, 126000cd) + HUGE size, huge head, huge battery, I really like ![]() Cons - nothing Other comment - Fenix use BAK C18650CC (2600mAh) cells in battery pack. This is a good battery, the performance is very similar than Sanyo UR18650FM, but I think a 6*18650 battery holder (optional accessory) would be very good for own batteries. Links User manual - http://www.fenixtactical.co... Youtube videos - Links and now the pictures.. if you need higher res pls click image, more photos coming soon, incl beamshots! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ----------------------------- RC40 vs Fenix TK35 U2 ![]() RC40 vs Fenix TK75 ![]() RC40 vs Olight SR51 ![]() RC40 vs Jetbeam DDR30 ![]() RC40 vs Blackshadow Terminator T6nw ![]() RC40 vs Microfire L500R V3 NW, Blackshadow Terminator T70, Thrunite TN35, Olight SR96 and Niwalker Nova MM15 ![]() ![]() ![]() ![]() ![]() next pic: distance ca. 350m! ![]() more beamshots coming soon |
