Просмотров в теме 2232   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.05.2014, 14:01 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию Foursevens Maelstrom MM-X with Burst mode (XM-L2, 900lm)
Hello guys, the newest gen of MM-X arrived few weeks ago, of course I made some pics and beamshots :sssh: btw the beamshot comparisons is not complete, I will add more photos later
Features
Strike-bezel
Current regulation
Shock-isolated battery compartment
Weapon mountable
Smart circuit for rechargeable batteries
Reverse-polarity protection
Burst mode
Specs
LED: Cree XM-L2 (CW)
Voltage range: 2.7V-8.4V
Brightness levels:
- Moonlight: 0.5lm (25days)
- Low: 32lm (21 hrs)
- Medium: 250lm (3.7 hrs)
- High: Burst at 900 lumens, 1 minute then 450 lumens, 1.5 hrs
Special modes:
- Strobe, 10Hz (1hr)
- SOS (4.5hrs)
- Beacon (12 hrs)
Spot beam: Angle 8 degrees, diameter at 3m: 430mm
Flood beam: Angle 60 degrees, diameter at 3m: 3.45m
Reflector surface: Smooth
Body material: Type-III hard-anodized aircraft-grade aluminum
Bezel material: Stainless steel strike-bezel
Lens material: Optical-grade glass lens, sapphire coating, antireflective coating
Dimensions: Length: 6 inches (15.2cm), Body diameter: 1 inch (2.5cm), Head diameter: 1.5 inches (3.8cm)
Weight (without batteries): 5.1 oz (144.5g)
Included accessories: Batteries (2*Foursevens CR123A Lithium, 1500mAh), Lanyard, Spare o-ring (3x), Holster, Non-crenated spare bezel, Flat grip-ring spacer
My impressions
Pros
+ excellent build quality
+ nice design
+ nice anodizing (no scratch etc.)
+ well centered led + very nice beam quality (no rings etc.)
+ no pwm flickering, all modes perfect!
+ perfectly silent driver (in all modes)
+ moonlight mode
+ well spaced modes
+ 18650 battery not rattle in body
+ extra non-crenated bezel
+ extra flat grip-ring spacer
+ 2*CR123A battery
Cons
- Not a real disadvantage for most people, but this flashlight not working with unprotected/flat top batteries. I like and I prefer the unprotected cells, so this is a small disadvantage for me.
Other comment
I think 3 or 5 mins burst mode would be better
the pics
MM-X vs Armytek Predator Pro/Viking Pro v2.5, Jetbeam DDR26, Olight M20SX-L2, M21X-L2, M22, Fenix PD35, TK35 U2
distance ~25-28m (trees)
gopajti вне форума   Ответить с цитированием Вверх
happy (21.05.2014)
Время генерации страницы 0.09147 секунды с 15 запросами
