Просмотров в теме 2829   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 20.05.2014, 14:00 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
По умолчанию **Pictures** Olight SR95S UT (Luminus SBT-70, 1250lm, 250.000cd)
SR95S UT arrived few days ago
Description
The SR95S UT offers an impressive modification to Olight's already capable SR95 Ultimate Thrower rescue light. The SBT-70 LED is the newest in high-output, far throwing technology. A specially designed reflector delivers light with the incredible range. Illumination for up to 1000 meters is possible with this light, making it an industry leader in performance, while an extra 250 lumens compared to the previous SR95 UT puts maximum output at 1250 Lumens.
A tough, full-bodied aluminum body holds a high capacity 7800 mAh, 7.4v rechargeable lithium battery. The body also features a charge indicator and integrated port for easy recharges. The unique engineering of the head and reflector features a "Hollow out" design for optimum heat dissipation and weight distribution. This gives the SR95S UT a balanced feel in the hand without too much weight at the head of the light.
Three output modes, constant and momentary on functions, and an incredibly brilliant strobe can be accessed with the large format side switch designed for rapid and comfortable use, even in thick gloves.
Key features
  • Material: Aluminum body with anti-scratching type III Hard Anodizing
  • Charger: AC 100-220V 50~60HZ input. Recharge under constant current and voltage) C3A/8.4V
  • Smooth reflector
  • Lens: Tough ultra-clear tempering glass, with anti-reflective coating
  • Striking bezel: Aluminum body with anti-scratching type III Hard Anodizing
  • Large side switch for easy activation, even in thick gloves
  • Features two gold plated, metal O Rings
  • Anti-slip ergonomic knurling
  • Beam intensity in center: 250.000 candela
  • Maximum throw: 1000 meters
  • Waterproof rating: IPX6
  • Impact resistant up to 1.5 meters
Specifications
  • LED: Luminus SBT-70 LED
  • Battery: 7800mAh 7.4V rechargeable lithium battery
  • Output/Run Time: 150lm (48h), 500lm (8h), 1250 Lumens (3h)
  • Dimensions: Length: 325mm, Head Diameter: 90mm, Body Diameter: 48.4mm
  • Weight: 1230.5g
Accessories
One shoulder strap, one AC Charger, one power cable for charger
Download manual (PDF)
link
Official website
http://www.olightworld.com/...
My impressions
+ Very nice packaging, suitcase
+ This is a HUGE flashlight, looks very impressive, I like the head "hollow out" design
+ Precisely centered led
+ Clean, dust free, lens, reflector with thick GITD red o-ring
+ Nice black anodizing
+ Smooth threads with thick O-rings
+ Battery indicator
+ New, bigger switch is better than my SR51., "softer" and more comfortable (and the switch button is glow in the dark)
+ Very comfortable shoulder strap
+ Stable tail stand to serve as a candle
+ Beautiful pure white tint (in all modes)
+ No irritating flickering (pwm etc.) (all modes are perfect)
+ Beam quality (absolutely no rings on the wall)
+ Active thermal management (not a simple step-down timer)
- disadvantage the head design, difficult to clean
Other: The battery pack is good, easy to use, but I would like to see a separate battery tube (optional accessory) with 6*18650 holder.
SR95S UT english review (selfbuilt)
And now the pics.. click images for higher res (I will add more pictures, incl beamshots)
Wall shots (distance ~70-80cm)
Beamshots, distance 220m (click images for higher res)
Olight SR95S UT vs Lumintop Hunter T5
Olight SR95S UT vs Armytek Barracuda
Olight SR95S UT vs Jetbeam DDR30
gopajti вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.10989 секунды с 15 запросами
