2942
Регистрация: 04.01.2013 Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
Hello guys, now Olight M20X-L2 and M21X-L2 are here, so I would like to show these flashlights, eg. compared with M22.
M20X-L2 - Use the latest in CREE XM-L2 (T6) LED, output raises up to 550 lumens - Three adjustable brightness levels: 550 lumens, 110 lumens, 10 lumens and 10Hz strobe - Innovative tactical user interface and dual tail switches; New UI assigns the dimmable function to tail-cap switch, which greatly facilitate tactical applications, especially via remote press switch. Tail side switch controls output brightness levels, three brightness levels “low-medium-high” changes by circle. Hold the button to activate strobe - Compatible with 2*CR123A/RCR123 or 1*18650 batteries - Battery polarity reverse protection - Water resistant up to IPX-7 - Equipped with a double CR123A size battery magazine - Rectangle threads, new pocket clip, as well as new position structure for cigar holder, which greatly raise its reliability - Lock-out function: press the tail switch and side switch simultaneously, the light will power off and then locked-out. Accessories Deluxe packing: Flashlight, Lanyard, Spare O-Rings (x2), CR123A (x2), White Diffuser, Holster, Battery Magazine, Silicon Rubber Boot (fluorescence) Ordinary packing: Flashlight, Lanyard, Spare O-Rings (x2), Battery Magazine, Silicon Rubber Boot (fluorescence) Optional accessories: Olight Brand CR123A Lithium Battery 3V 1500mA, OLIGHT Weapon Mount WM20, OLIGHT Magnet Weapon Mount X-WM01, OLIGHT Magnet Weapon Mount X-WM02, Stainless steel striking bezel, Traffic wand (white, orange), Filter (white, red, green, blue), RM20S Remote Tactical Switch (two buttons, rectangle thread), 3 keys remote pressure switch (rectangle thread). my impressions coming soon M21X-L2 - Utilizing the newest Cree XM-L2 (T6) LED, output increased by 20% - High-efficient drive circuit, the highest output reaches 750 lumens, and beam distance is up to 288m - Multi-functional tail switch: Under off status, lightly press the tail switch will perform momentary-on, while twice quick clicks will activate high brightness and triple quick clicks will activate strobe, further full press will acquiesce in outputs. Under on status, full press the tail switch will perform power off. - Three adjustable brightness levels (low-medium-high), changeable in cycle through screwing the head from loose to tight - Anti-rolling cigar holder is convenient for steady holding the flashlight; and there is a 3mm diameter hole can pass through fabric strap - Aviation grade aluminum body, with anti-scratch type III hard anodizing - Blackening treatment stainless steel striking bezel also available - Time limit high brightness steps down. After 5 minutes running, output on high will drop down to 60%. Restart the flashlight or reactivate the high brightness level to recover. Accessories Deluxe packing: Flashlight, Lanyard, Spare O-Rings (x2), White Diffuser, CR123A (x2), Holster, Battery Magazine, Silicon Rubber Boot (fluorescence) Ordinary packing: Flashlight, Lanyard, Spare O-Rings (x2), Battery Magazine, Silicon Rubber Boot (fluorescence) Optional accessories: Olight Brand CR123A Lithium Battery 3V 1500mA, OLIGHT Weapon Mount WM20, OLIGHT Magnet Weapon Mount X-WM01, OLIGHT Magnet Weapon Mount X-WM02, Stainless steel striking bezel, Traffic wand (white, orange), Filter (white, red, green, blue), Remote pressure switch. my impressions coming soon M22 Warrior - Utilizing the newest Cree XM-L2 (T6) LED to enhance the lumen output. - High efficiency driver circuit allows maximum 950 lm output & 305 meter beam projection. - Three adjustable brightness levels (low-medium-high). - Thick stainless steel bezel protects the lens, and makes a great defensive tool. - Anti-scratch type III hard anodizing aluminum body. - Large surface of heat sink on its head, allowing for efficient heat dissipation. - High efficiency smooth reflector 99% luminousness ultra-clear lens with anti-reflective coating. - Multi-function tail forward switch. Under off status, lightly press the tail switch will perform momentary light, while twice continual quick clicks will activate high brightness and triple clicks will activate strobe, further hard press will acquiesce in outputs. Under on status, hard press will power off the light. - It allows you to go from low/med straight to Turbo or Strobe one-handed with a reverse grip (thumb on tail switch) Standard accessories: White filter, Holster, Battery Magazine, Lanyard, O-ring, Silicon rubber boot Optional accessories: Remote Pressure Switch, Weapon Mount, Filters (Green, Red or Blue), Traffic wand my impressions coming soon ![]() Pictures, more pics coming soon! If you need higher res, pls click images ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() more M22 pics http://www.candlepowerforum... --------------- distance approx.: 10-12m (32-39ft) ![]() ![]() ![]() other beamshots ![]() ![]() ![]() M20X-L2, M21X-L2, M22 vs Spark SL6S-740NW ![]() ![]() ![]() M20X-L2, M21X-L2, M22 vs Jetbeam DDR26 ![]() ![]() ![]() M20X-L2, M21X-L2, M22 vs Armytek Predator Pro v2.5 ![]() ![]() ![]() M20X-L2, M21X-L2, M22 vs Armytek Viking Pro v2.5 ![]() ![]() ![]() M20X-L2, M21X-L2, M22 vs Microfire M2C Multicolor ![]() ![]() ![]() more beamshot pics coming soon! |
| Поблагодарили: 7 раз(а) |
Admin (20.05.2014), andyz (20.05.2014), blackwolf762 (20.05.2014), Gradientt (07.06.2014), happy (21.05.2014), Linx (22.05.2014), selenopolis (22.05.2014)
Регистрация: 25.03.2014 Последняя активность: 26.02.2015 19:55
Сказал(а) спасибо: 320
Поблагодарили: 260 раз(а) в 143 сообщениях
Great job, thank you!
