Просмотров в теме 10906   Ответов в теме 7   Подписчиков на тему 4   Добавили в закладки 0
Старый 20.05.2014, 13:15 Автор темы   1
Аватар для gopajti
Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
Thumbs up Fenix TK35 UE and TK35 L2 - Pictures, Impressions
I'm gopajti from CPF/TLF I would like to share my photos/impressions on this forum, I hope you like it. Greetings from Hungary!
Hello guys, one of the best all around flashlights arrived today, Fenix TK35 L2 and TK35 Ultimate Edition. So I would like to show these flashlights. Let's see how working XM-L2 vs MT-G2 side by side. I hope this post will help for choice.
Fenix TK35 (Cree XM-L2 U2 CW LED)
Official,
Description
Fenix TK35 is a high-intensity multi-functional flashlight. Using CREE XM-L2 U2 LED, it delivers a max 900-lumen output with two 18650 batteries or four CR123A batteries. Offering 4 brightness levels, strobe and SOS function, dual tail switches, TK35 excels in various outdoor activities, such as exploring, camping, searching, caving and more.
Features
- Cree XM-L2 (U2) LED with a lifespan of 50,000 hours
- Uses four 3V CR123A batteries (Lithium) or two 18650 rechargeable batteries (Li-ion)
- 165mm (Length) x44mm (Diameter) x52mm (Head)
- 275-gram weight (excluding batteries)
- Digitally regulated output - maintains constant brightness
- Reverse polarity protection, to protect from improper battery installation
- Low-voltage warning function, to remind users of low power
- Dual button switch in the tail cap, convenient operation
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Toughened ultra-clear glass lens with anti-reflective coating
My Impressions (TK35 L2)
Pros
+ Very good build quality as always from Fenix
+ Nice black anodizing without any scratches
+ Aluminium tailcap (not plastic as old first gen TK35 XM-L T6)
+ Nice beam, not visible rings etc. the led is well centered (not 100% perfect but good)
+ I have not seen PWM or other irritating flickering, not hear buzzing sounds etc, all mode OK!
+ Unprotected/flat top batteries support
+ The mode selection switch reaction time is perfect, react immediately
+ Simple UI with well spaced modes
+ Hidden modes (SOS, Strobe)
+ Relative compact size
+ Good throwing capable
+ Good quality holster, lanyard
Cons
- The reflector surface is slightly dusty
- Switches plastic parts slightly rattle (inside in the tailcap)
Fenix TK35 Ultimate Edition (Cree MT-G2 NW LED, 5000K)
Official,
Description
Some boundaries are made to be pushed. Thanks to the revolutionary Cree MT-G2 LED, the TK35 Ultimate Edition produces 1800-lumen maximum output while still keeps the size and power options in tact. Besides the output boost, the neutral white Cree MT-G2 LED also provides better color rendition. The light features dual tail switch system for one hand operation.
Features
- Utilizes Cree MT-G2 LED with a lifespan of 50,000 hours
- Uses two 18650 rechargeable batteries (Li-ion) or four 3V
- CR123A batteries (Lithium)
- 165mm (Length) × 44mm (Diameter) × 52mm (Head)
- 265-gram weight (excluding batteries)
- Reverse polarity protection to protect from improper
- battery installation
- Low-voltage warning function to remind users of low power
- Dual button switch in the tail, convenient operation
My Impressions (TK35 UE)
Pros
+ Nice packaging, design (box)
+ Clean reflector, lens
+ Absolutely perfect beam quality with very nice neutral white tint. The MT-G2 led is really awesome
+ Well centered LED (not 100% perfect, but close to perfect)
+ Well spaced modes (25lm, 250lm, 750lm, 1800lm) with hidden extra modes (SOS, Strobe)
+ Better, more useable beam in short distances, much better than XM-L2 version
Cons
Other comments
- If needed, you can use TK35 in candle mode, but only on stable, horizontal surfaces.
- TK35 UE has not perfect flat regulation in 1800 lumen mode, but in real life this is not big problem I think. If need more info about regulation, pls check selfbuilt review.
- I think TK35 would be better with side switches, would be more comfortable to everyday use.
For me: The winner is, TK35 UE and the MT-G2 LED!
Otherwise, I hope TK61 UE will be available later... I think TK61 huge reflector with 4 (or more) 18650 battery would be perfect combination with MT-G2 LED. My TK61 thread here
What I recommend (batteries, chargers etc.)
Protected 18650 li-ion batteries: Fenix ARB-L2S 3400mAh, Keeppower 2600mAh, 2900mAh (Panasonic NCR18650PF cell), 3400mAh, 3600mAh, Orbtronic cells
Unprotected 18650 li-ion batteries for advanced users: Sanyo UR18650FM 2600mAh, Panasonic NCR18650PF 2900mAh, Panasonic NCR18650B 3400mAh, NCR18650G 3600mAh
Charger(s): XTAR WP2 II (2014), XTAR VP1
XM-L2 U2 with smooth reflector (left) vs huge MT-G2 LED with orange peel ref. (right)
more photos coming soon!
[Исправлено: gopajti, 20.05.2014 в 13:23]
gopajti вне форума   Ответить с цитированием Вверх
Поблагодарили: 8 раз(а)
Admin (20.05.2014), Fonarik.com (04.11.2014), happy (20.05.2014), Ikepod (05.10.2014), jakovjashin (20.05.2014), Svetogor (30.06.2014), Псевдоним (20.05.2014), терХан (03.01.2015)
Старый 20.05.2014, 13:17 Автор темы   2
gopajti
Аватар для gopajti
По умолчанию Re: Fenix TK35 UE & TK35 L2 - Pictures, Impressions
more beamshot pics coming soon
Поблагодарили: 26 раз(а)
99amper (30.06.2014), Admin (20.05.2014), alpg88 (09.11.2014), andyz (20.05.2014), crus (20.05.2014), dmn42 (20.05.2014), Fonarik.com (04.11.2014), Ikepod (05.10.2014), jakovjashin (20.05.2014), KAR2009 (16.11.2014), Kelevratony (20.05.2014), Khii! (26.12.2014), ko54 (20.05.2014), Martine (20.05.2014), martinos (14.08.2016), Mongol78 (04.11.2014), nokiaf (04.11.2014), pazik (05.10.2014), proba999 (26.01.2015), Qwertus (20.05.2014), serj_32 (17.08.2014), Svetogor (22.05.2014), TimK (20.05.2014), Андрей 31 (13.01.2015), Псевдоним (20.05.2014), терХан (29.06.2014)
Старый 20.05.2014, 13:23   3
andyz
старожил
Аватар для andyz
Сказал(а) спасибо: 661
По умолчанию Re: Fenix TK35 UE and TK35 L2 - Pictures, Impressions
Very nice photos!
Околофонарные мелочи
Старый 20.05.2014, 13:31   4
Sergey@yeisk
Капитан Очевидность
Аватар для Sergey@yeisk
Сказал(а) спасибо: 286
Да, снимки шикарные
Флудер из ТК35 неплохой получился. Ещё бы степдауна не было...
Старый 20.05.2014, 13:42   5
ostro169
Аватар для ostro169
Последняя активность: 28.10.2025 10:26
Сказал(а) спасибо: 389
Поблагодарили: 111 раз(а) в 47 сообщениях
Феникс сделал прикольный лёгкий флудер, кстати очень заметно, насколько холодный свет у обычного TK35:
Налобные: Petzl Tikka, Tikka XP2, fenix HL30, HP20, HP30, HL55, Zebralight H600w Mkll, H52Fw, ЯЛ enot lh-140, ЯЛ enot lh-500, Skilhunt H03 (tamagotchi), Skilhunt H04RC, fenix hl23, YLP Panda 4.0
Ручные: Fenix E05, Tank007 E09, Meteor M43, Niwalker VOSTRO BK-FA02, Convoy S2+, в т.ч. UV Nichia 365nm, Olight S10 mod.Fnskb (nichia219+TIR), DQG AAA Tail Clicky NW, maglite solitaire AAA, Convoy 4x18A SBT90.2, Convoy L21B SFT40, BLF LT1, Lumintop GT3, Emisar D18, Emisar D4V2, Noctigon KR4, sipik68 RGB
ostro169 вне форума   Ответить с цитированием Вверх
Старый 20.05.2014, 15:38   6
Martine
Аватар для Martine
Последняя активность: 28.04.2021 20:33
Сказал(а) спасибо: 199
Поблагодарили: 213 раз(а) в 102 сообщениях
Интересно какая будет цена на Украине.
Martine вне форума   Ответить с цитированием Вверх
Старый 30.06.2014, 11:31   7
mamiya
Аватар для mamiya
Последняя активность: 13.09.2024 16:48
Сказал(а) спасибо: 232
Поблагодарили: 36 раз(а) в 27 сообщениях
Да, снимки шикарные
Без степдауна он просто напросто розплавился б.
mamiya вне форума   Ответить с цитированием Вверх
Старый 04.11.2014, 12:02   8
Vovyala
Аватар для Vovyala
Последняя активность: 16.03.2022 06:34
Сказал(а) спасибо: 393
Поблагодарили: 301 раз(а) в 129 сообщениях
gopajti, Dear Gopajti, good day.
Have you beamshots of Nova mm15 ?
Same as TK35 ?
Thank you.
Vovyala вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.14120 секунды с 15 запросами
