Просмотров в теме 3320   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 19.05.2014, 12:18 Автор темы   1
Аватар для selfbuilt
Последняя активность: 10.11.2015 10:40
По умолчанию Thrunite T10S (XP-G2, 1xAA, Stainless Steel) Review: RUNTIMES, BEAMSHOTS, VIDEO+
The T10S is the new stainless steel version of the T10 from Thrunite. But it is more than just a material change – the T10S also features a reverse clicky switch, and the latest XP-G2 emitter.
Let’s see how it compares to the competition. :whistle:
Manufacturer Reported Specifications:
(note: as always, these are simply what the manufacturer provides – scroll down to see my actual testing results).
  • LED: Cree XP-G2
  • Three modes of output: Low (0.2 lumens, 147hrs), Medium (20 lumens, 39hrs), High (169 lumens, 1.5hrs)
  • Uses one 1.5V AA battery.
  • Max output: 169 lumens with XP-G2.
  • Working voltage: 0.9V-3V
  • Peak beam intensity: 1602cd
  • Peak beam distance: 80m
  • Reverse polarity protection design to protect from improper battery installation.
  • Tail-switch and twisting head design.
  • Stainless steel body.
  • Toughened ultra-clear glass lens with anti-reflective coating.
  • OP reflector gives perfect flood.
  • Removable clip.
  • Stand on tail to serve as a candle, with the wand covered on the head.
  • Impact resistance: 1.5M
  • Waterproof: IPX8 (2M)
  • Dimensions: 93.5mm (Length) x 19mm (Diameter).
  • 63.5g weight (without battery).
  • MSRP: $40
Packaging is stylish, with a light-weight metal case with clear display window. Inside, in packing foam is the light, diffuser wand, extra o-ring, pocket clip with screws and mini-Allen key, and manual.
From left to right: Duracell NiMH AA; Thrunite T10S; T10; Zebralight SC52; Rofis ER12; Fenix E11, LD12; JetBeam E3S; L3 Illumination L10.
All dimensions directly measured, and given with no batteries installed:
Thrunite T10S: Weight: 60.9g; Length: 93.7mm, Width (bezel): 17.8mm, Width (widest): 18.7mm
L3 Illumination L10: Weight: 20.7g, Length: 79.4mm, Width (bezel): 17.1mm
ArmyTek A1 XP-G: Weight: 57.3g, Length: 96.8mm , Width (bezel): 23.1mm
Fenix LD12: Weight: 52.3g, Length: 99.9mm, Width (bezel): 21.6mm
Foursevens Mini AA: Weight: 17.6g, Length: 78.2mm, Width (bezel): 17.6mm
Olight S15 1xAA: Weight: 46.4g, Length: 87.0mm, Width (bezel): 23.1mm
Nitecore EA1: Weight: 50.6g, Length: 84.3mm, Width (bezel): 25.41mm
Nitecore MT1A: Weight: 54.6g, Length: 104.6mm, Width (bezel): 22.7mm
Nitecore SENS AA: Weight: 26.1g, Length: 82.7mm, Width (bezel): 19.8mm
Lumintop ED15: Weight: 59.7g, Length: 100.2, Width (bezel): 21.9mm
Zebralight SC52: Weight 39.5g, Length 79.0mm, Width (bezel): 22.6mm, Width (max) 25.4mm
Rofis ER12: Wright: 35.5g, Length: 96.2mm, Width (bezel): 18.6mm
Xeno E03:: Weight: 48.1g, Length 96.7mm, Width (bezel): 21.5mm
As you can see, the stainless steel construction adds a bit weight to the T10S. Overall dimensions are still quite reasonable for this class.
The T10S has a solid stainless steel construction, with a brushed finish. Labels are in black, but fairly unobtrusive. There is no knurling to speak of, but there are fluted ridges on the head. This are sufficient to allow you operate the light one-handed (i.e., you can twist the head one-handed).
I recommend you install the included pocket clip – not only does it help with grip, bit it serves as an effective anti-roll device (otherwise, there is nothing to stop rolling). The clip is not very large, and fairly lightweight, but seems to work alright as a pocket clip. It reminds me a lot of the clip that comes on the Jetbeam RRT-0 - and is similarly fastened by a pair of screws.
The light's screw threads are standard triangular cut, fairly fine (like most lights in this class). As with all small lights, you can expect some play with the threads. There is also potentially greater resistance than most aluminum lights. But I found performance to be decent for stainless steel. Interestingly, the light can still function as a twisty (i.e., contact is only made when the head is fully tight against the body). I presume the contact plate in the head is isolated from the body.
There is a physical clicky in the tail, under a stainless steel boot cover. Switch is the reverse-clicky type (i.e., press and release to turn on/off), although you can potentially change modes by a soft-press. Scroll down to the User Interface section for more info.
There are raised lanyard attachment points at the base of the tail, with cut-outs. As such, the lights can all tailstand stably. However, the actual switch is still somewhat recessed (due to the low-profile switch and boot cover).
Interestingly, the T10S comes with a diffuser wand attachment, which fits securely on the light.
Centering of the XP-G2 cool white emitter was good on my sample. As expected, the reflector is not very deep, and has an orange peel (OP) texturing to help smooth out the beam. Please see my detailed beamshots later in this review.
User Interface
The T10S has a revised interface from the earlier T10.
With the head fully tight, turn the light on or off by the tail switch. Switch is basically a reverse clicky switch, so you need to fully press and release to activate the light (i.e., click and release).
However, you are able to switch modes by either full off/on clicks of the switch, or a partial soft-press and release. Pressure required for the soft press takes a little getting used to, but does work (and is rare on a reverse clicky switch). Mode sequence is Lo > Med > Hi, in repeating sequence.
Thoughtfully, the T10S still works as a twisty-style light. With the switch clicked in the On position, you can turn the light off/on or change modes by a simple loosen/tighten twist of the head.
There is mode memory, if you wait at least 2 secs after turning the light off before re-activating. Otherwise, you will simply change modes.
There is no strobe or SOS mode on the T10S.
Video:
For information on the light, including the build and user interface, please see my video overview:
Video was recorded in 720p, but YouTube typically defaults to 360p. Once the video is running, you can click on the configuration settings icon and select the higher 480p to 720p options. You can also run full-screen.
As with all my videos, I recommend you have annotations turned on. I commonly update the commentary with additional information or clarifications before publicly releasing the video.
PWM
There is no sign of PWM at any output level, on any model. The T10S is current-controlled.
I did however detect some variable high frequency noise on my sample, on Med and Hi (but not Lo):
Consistent with my standard review policy, I report on any oscilloscope signals that I can detect in the output of a light. But I can assure you that the above patterns produce no visible effect – even when shining on a fan. The light was "flicker-free" at all levels in my testing.
As mentioned above, there is no strobe or SOS mode on the T10S.
Beamshots:
For white-wall beamshots below, all lights are on Max output on a Sanyo Eneloop NiMH (2000mAh). Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
The T10S has a reasonable beam profile for a 1xAA light. No real surprises here – the T10S has more output and throw than some, less than others. Scroll down to my detailed testing results.
Testing Method:
All my output numbers are relative for my home-made light box setup, as described on my flashlightreviews.ca website. You can directly compare all my relative output values from different reviews - i.e. an output value of "10" in one graph is the same as "10" in another. All runtimes are done under a cooling fan, except for any extended run Lo/Min modes (i.e. >12 hours) which are done without cooling.
I have devised a method for converting my lightbox relative output values (ROV) to estimated Lumens. See my How to convert Selfbuilt's Lightbox values to Lumens thread for more info.
My summary tables are reported in a manner consistent with the ANSI FL-1 standard for flashlight testing. Please see http://www.flashlightreview... for a discussion, and a description of all the terms used in these tables. Effective July 2012, I have updated all my Peak Intensity/Beam Distance measures with a NIST-certified Extech EA31 lightmeter (orange highlights).
The T10S has reasonably bright max output, toward the higher end of my other XP-G/XP-G2 lights. Peak intensity throw is also reasonable, for the size head.
The Lo level is quite low for the class, and is a true "Moonlight" low level.
Let's see an output breakdown for all levels, relative to the specs:
As you can see, my numbers match pretty well to Thrunite's specs. Relative mode spacing is reasonable, although absolute levels are really more of a Moonlight > Med > Hi spacing.
The T10S does not support 14500 Li-ion.
Runtimes
Runtime on Hi is within the range of other current-controlled members of this class.
Runtime on Med is excellent for the class.
Potential Issues
Light will roll easily, unless you install the pocket clip.
Stainless steel lights are heavier than aluminum ones in this size (although the T10S is one of the most compact SS lights I've seen).
Lowest level is Moonlight (i.e., there is no typical "Lo" level).
Pressure required on the switch to "soft-press" through output modes takes some getting used to. However, this is still an improvement over most reverse-clicky lights, where it is not possible at all. And twisty control has also thoughtfully been maintained.
14500 (3.7V Li-ion) is not supported.
Preliminary Observations
The T10S is a nice update of the 1xAA T10 from Thrunite. Importantly, you can still use the light as a simple twisty. But you now have clicky switch control as well. Oh, and the build has been completely revamped to a sturdier, brushed stainless steel. :wave:
The clicky switch is interesting. Although it functions as a reverse clicky (i.e., fully press and release to turn on/off), you don't need to do a full "click" to change modes. The ability to "soft press" and release for mode switching is unusual in a reserve clicky (although it does take some practice to get the pressure right for this maneuver). But that's no problem – you can always change modes by a full click, or by the original head twist. It is thoughtful that they kept the contact board isolated from the body, allowing you to use it as a traditional twisty light. :twothumbs
Physically, this is a good design for a stainless steel light, in my opinion. A lot of the time, there really isn't much in the way of grip on these lights (and they can often be a fairly bulky). The T10S is distinctive in that it is still fairly compact, but with a raised head area with fluted indentations to help with grip. This means that you can easily run the light single-handed, twisty-style. The only minor recommendation I would make is to raise the profile of the clicky switch a little further (given there is still some tailstanding range withing the lanyard attachment point).
Mode spacing is a little unusual for a 3-stage light (i.e., really more of a Moonlight – "Lowish" Med – Hi sequence). But that's fine with me, since I find the lower levels are what I use the most in an EDC-style 1xAA light.
In terms of output/runtime performance, the current-controlled circuit worked consistently well in my testing. Runtimes are very good for the class, especially on the "Med" level.
Beam pattern is good for a XP-G2 light of this size. No, it is not a heavy thrower, but it does have a bit more throw than a typical slim-lined 1xAA light. No significant beam artifacts or issues on my sample. And the included beam diffuser wand is a nice touch.
I'm not usually a big fan of stainless steel lights, as I find aluminum to be solid enough and easier for every day carry and use. But the T10S is a relatively compact offering in this space, with a good range of features and design. Certainly a good choice to consider in this group.
T10S provided by Thrunite for review.
selfbuilt вне форума   Ответить с цитированием Вверх
Admin (19.05.2014), blackwolf762 (19.05.2014)
Время генерации страницы 0.12976 секунды с 15 запросами
