Вернуться   Форум FONAREVKA.RU Торговая площадка Специальные предложения
Просмотров в теме 6438   Ответов в теме 34   Подписчиков на тему 3   Добавили в закладки 0
Старый 14.05.2014, 14:27 Автор темы   1
Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
По умолчанию Wallbuys New Arrival and Special Offer
I have no idea if you know Wallbusy' new coupon code in 2014.Type again: LEDWALLBUYS14(10%off for most products excluded some special offer item) and WB added some good lights and charger recently
I am here to open the information, hope it helps you somewhat
Every week I will post several great lights in good price from WB, please keep close attention on this thread
As I said, any good new product recommendations and suggestions are welcomed here, don't hesitate to write down your word
1, Imalent LCD Flashlight, Maybe most of you heard about that kind of light this year, you could heard about good or bad comments on the other forums as well, some people said that Imalent LCD flashlight more like a toy than a tool, or they are totally nitecore's clone though, I thought wise see wisdom, you have your own choice, and we have to admit that Imalent flashlights do have a good UI and innovative design, also, they are high performance in some case. Whatever, here is WB's 15% off coupon code: WBIMALENTEMT16
http://e.wallbuys.com/Subje...
2, Opus BT-C3100 V2.0 LCD Battery Charger I have to emphasis that the charger that I am introducing to you is very popular now
We got both US and EU plug version
WB added the charger into our store because of WB's customers' recommendation, and thanks
We offer a 35% off coupon code for the charger:OPUSBTC3100V2
US plug:
http://wallbuys.com/Product...
EU plug:
3, MAXTOCH 2S ,As I known, lots of people are interested in that light.Though it is not that easy to get in Chinese market, at present, we got 2S, and we are still trying to get the other models, like M12, SN6X-2X, and DX21. just keep close eye on WB
you can get this light in the price of 65.16$ with coupon code(LEDWALLBUYS14) , it quite a good deal
4, Ultrafire F17, a good budget light, hope you would like it, $11.58 with coupon code
5,Fenix TK61, $134 with the code, pretty good price
cherryzhou вне форума   Ответить с цитированием Вверх
Старый 14.05.2014, 14:42   2
andyz
старожил
Аватар для andyz
Сказал(а) спасибо: 661
По умолчанию Re: Wallbuys New Arrival and Special Offer
Thanks for info, hope it's not single action.
The question is about item 2: have them in stock or how long
waiting before shipment?
Околофонарные мелочи
Старый 15.05.2014, 09:26 Автор темы   3
cherryzhou
Посмотреть сообщение Сообщение от andyz :
Hi, thanks for your attention
It will take 1-2 days to get the chargers from the manufacturer, and the coupon code is valid until the end of June.
Any problems feel free to contact with me
Старый 15.05.2014, 09:28   4
andyz
старожил
Аватар для andyz
Посмотреть сообщение Сообщение от cherryzhou :
Thanks, noted.
Старый 15.05.2014, 12:06 Автор темы   5
cherryzhou
New version of BLACKSHADOW TERMINATOR T70 $103.34 with coupon code
Higher performance than the old version
Improvements:
1. Emitter :Four pieces newest CREE XM-L2 LED.
2. PWM:Rise the frequency of the original PWM, it’s not visible now.
3. Handle: Removable.
4. Functions of Switch:
Slightly click the switch to access to Momentary-light-on function
Long-press the switch to turn on/ off the light,light is automatically locked on High mode after being turned on.
Single-click the switch to change different brightness modes, High-Middle-Low.
Double-click the switch to access to hidden Strobe mode.
We are considering a group buy
5-10 pcs $95
over 10pcs $90
over 30pcs $82
if you guys are interested in this group buy, please don't hesitate to write down "interested + quantities"
for example: " interested + 1"
have any good ideas ,just tell me
Старый 15.05.2014, 12:07   6
andyz
старожил
Аватар для andyz
I'm in for 1.
Старый 15.05.2014, 12:10 Автор темы   7
cherryzhou
Hi, andyz
Thanks for you support
I Got it, I will keep you informed once I summarized the quantity and set a group buy
Старый 16.05.2014, 12:55 Автор темы   8
cherryzhou
The T70 GB reach around 20pcs now, you can get the price of $90 now,and the group buy will be hold tomorrow, just keep an eye on us
[Исправлено: cherryzhou, 16.05.2014 в 13:14]
Старый 16.05.2014, 13:08 Автор темы   9
cherryzhou
JAX-COLT X6 CREE XM-L2 U3-1A 1200LM 2-Group 8-Mode White LED Flashlight-Black(1x26650/2x26650)
$62.96 with coupon code
Features:
Shell: stainless steel attract head(Diameter:68mm)
LED: Newest version of 1 x XM-L2 U3 1A
Lens: Double coated lens (Thickness:3mm)
Reflector: Aluminum Smooth reflector, larger and deeper reflector (Diameter: 61mm)
Driver: High quality protected circuit compatible with single and double lithium batteries, high output of 2800mA to 3200mA, features low voltage warning,
Mode: Group 1:Low(5%)-Mid(50%)-High(100%)
Group 2:Strobe-SOS-Low(5%)-Mid(50%)-High(100%)
Mode Operation: Switch to low mode and wait for 5 seconds. As soon as you notice a quick blink, turn off the light instantly, after about 5s,turn on the light and mode group is then toggled.
Specials:
The flashlight utilizes pure bronze lamp base, super large pure bronze circuit compartment works with high quality silicone grease make the light’s performance of heat conduction nice, and minimize the temperature difference between inside and outside. With perfect light spot and long beam distance up to 700-800m, the beam distance max up to 900m (no light pollution)
It’s really a good choice for hunting , searching and caving
Старый 18.05.2014, 03:52   10
АlexxX
Последняя активность: 13.04.2017 00:00
Сказал(а) спасибо: 157
Поблагодарили: 19 раз(а) в 12 сообщениях
interested + 1
АlexxX вне форума   Ответить с цитированием Вверх
Старый 18.05.2014, 04:05   11
andyz
старожил
Аватар для andyz
Группбай уже запущен:
http://wallbuys.com/groupbu...
Старый 18.05.2014, 11:45   12
АlexxX
Уточните как работает этот групбай, цена уже не будет ниже 90$ , даже если будет более 30 участников ?
Старый 18.05.2014, 11:57   13
andyz
старожил
Аватар для andyz
Скорее всего не будет, на BLF порядка 15 человек записалось.
АlexxX (18.05.2014)
Старый 18.05.2014, 20:31   14
happy
Аватар для happy
Последняя активность: 26.02.2015 19:55
Сказал(а) спасибо: 320
Поблагодарили: 260 раз(а) в 143 сообщениях
BLACKSHADOW Terminator T70
+1
happy вне форума   Ответить с цитированием Вверх
Старый 19.05.2014, 03:08   15
andyz
старожил
Аватар для andyz
АlexxX,
Все-таки набралось более 30 человек на BLF, инициатор обещал связаться
с WB на предмет снижения цены до $82 сегодня. Нужно немного подождать.
АlexxX (19.05.2014)
Старый 19.05.2014, 07:23 Автор темы   16
cherryzhou
Посмотреть сообщение Сообщение от АlexxX :
interested + 1
Thanks for reading and reviewing
The quantity reached 30 pcs , That's to say , the GB price is $82
Click here to participate
Time: May 19th to May 22th
The light will be delivered on May 28th(around), as we need take time for collecting
Старый 19.05.2014, 07:41 Автор темы   17
cherryzhou
interested + 1
Thanks for reading, the quantity of T70 reached 30pcs, that's to say, the GB price is $82
The light will be delivered on May 28th(around), as it takes time for collecting
Старый 19.05.2014, 07:43 Автор темы   18
cherryzhou
interested + 1
Старый 19.05.2014, 07:46 Автор темы   19
cherryzhou
Hi, Thanks for reading and reviewing, the quantity reached over 30 pcs now, the price drop to $82
Старый 19.05.2014, 09:53   20
happy
Аватар для happy
Sorry, but can you recommend prefered delivery service for Russia?
Чем заказывать, товарищи?
..Хм, хотя не могу выбрать ничего кроме Swiss Post..
[Исправлено: happy, 19.05.2014 в 11:35]
Время генерации страницы 0.15518 секунды с 15 запросами
