261523
693
58
![]() Регистрация: 08.08.2011 Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
Hello Everyone,
Latest release! SKILHUNT H02 820 lumens headlamp. More ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() H02 headlamp LED: CREE XM-L2 Max output: ANSI 820 Lumens / 960 LED Lumens Max runtime: 120 hours Max beam distance: 105 meters Max peak beam intensity: 2800cd Waterproof: IPX-8 Impact resistant: 1.5 Meter Battery: 1x18650 or 2x CR123A Rated Range: 3V ~ 6V Dimension: Length 109mm/4.29inch Head diameter 24mm/0.94inch Body diameter 22.8mm/0.9inch Weight: 63g (without battery) Accessories: Headband (Detachable straps with silicone holder ) , clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring Features 1. Super bright & lastest CREE XM-L2 LED, High-performance, High-efficiency and energy conservation. 2. 960 LED lumens of light. Extremely bright headlamp powered by one 18650 Li-Ion battery. 3. Bead surface lens, wide and uniform flood beamshot. Max beam distance 105 meters. 4. Detachable straps with silicone holder, multiple, adjustable flashlight positioning loops. 5. Flat tail cap with strong magnet to secure to ferrous surfaces. 6. Rugged indestructible aluminum body with anti-scratching type III hard anodization. 7. Multi-level dissipating heat design, excellent heat dissipation. 8. Side switch button to transferring mode user-friendly interface to adjust output. 9. Four output levels and strobe, suitable for different environment. 10. Wide input range provides more choices of batteries. 11. Automatic memory function, remember bast used setting and can be preset to specific output mode for instant access. 12. Reverse polarity protection, to protect from improper battery installation. 13. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery on time. 14. Engineered anti-slip knurling for a tightly firm grip. 15. Dual recoil absorbing springs, battery impact resistance. 16. Tail stand as a candle-light. 17. Tail hand hole design for lanyard use, to prevent accidental dropping. |
| Поблагодарили: 16 раз(а) |
Alex4479666 (05.05.2014), blackwolf762 (04.05.2014), Dnv (03.02.2016), dr oleg (21.06.2014), fnksb (04.05.2014), happy (04.05.2014), havoc (04.05.2014), ilyasov1 (05.05.2014), John Jack (20.06.2014), kuromax (24.12.2015), Mihalich (30.05.2014), NazarSunrise (04.05.2014), sumro (05.05.2014), Tim_ON (06.05.2014), ujeen (08.05.2014), _rider (05.05.2014)
Шурик с шуриком
режимы ужасные
вместо 550 лучше бы сотню сделали
только у меня в игнор-листе полный список форумных садомитов |
LEV-UA (06.05.2014)
Сказал(а) спасибо: 208
Начали копировать армитеки
Регистрация: 25.03.2014 Последняя активность: 26.02.2015 19:55
Сказал(а) спасибо: 320
Поблагодарили: 260 раз(а) в 143 сообщениях
Сказал(а) спасибо: 5056
Фонарь действительно неплох. Скоро поглядим как собран.
А вот с режимами напортачили.. Лучше бы 550 турбо, а остальные 100, 35, 15, 5Лм. У меня в зебре самый востребованный повседневный 45Лм.
LEV-UA (06.05.2014)
Hoвичёк фонарёвки.
Регистрация: 18.08.2012 Последняя активность: 09.12.2025 20:30
Сказал(а) спасибо: 1991
Интересно, насколько легко будет заменить диод.
Да и вообще разобрать для замены драйвера и.т.д
Ну головы у многих Скилхантов поддаются разборке но основательно заклеены.
Иван Грозный (27.09.2014)
Регистрация: 27.05.2011 Последняя активность: Сегодня 13:24
Сказал(а) спасибо: 6699
видимо у каждого бренда есть засланец-диверсант среди разработчиков (или скорее руководителей, выдающих техзадание). чтоб испортить задумку.
фонарь одного режима, елки. |
Регистрация: 07.07.2010 Последняя активность: 09.06.2020 10:48
Сказал(а) спасибо: 59
Поблагодарили: 220 раз(а) в 87 сообщениях
Шурик с шуриком
galex, почему одного? двух, 5 люм тоже полезными бывают)
а вот турбо и 550 и правда в топку |
для графа де ля фер это слишком мало, а для мушкетера атоса - слишком много
![]() ни как мунлайт, ни как один из рабочих - ни то ни се. остальные же якобы 3 режима - по сути всего 1. я вообще уже ничего не понимаю, как? КАК! так можно придумать такое безумие - 3 одинаковоярких и один очень тусклый. для полной картины не хватает только насадки-зумнасоса |
asket32420 (05.05.2014)
Регистрация: 22.01.2012 Последняя активность: 20.07.2024 21:51
Сказал(а) спасибо: 948
я так же думал пока режимы не увидел.
+1
SC51, Н600F, H602w, H600w mkII, Niteye JA10, ThruNite TN10 (NW), Jetbeam BC40, Bronte X03 (NW), Bronte RA04 (NW XM-L), Tank007 e09, Xeno E03, Olight S20 |
Hoвичёк фонарёвки.
Имхо тоже фигня была бы. 5 люмен и 0,5 - это считай один режим, как и 100 и 50. Двухкратная разница на глаз мало заметна.
Идеально было 5-50-200-700+ люмен. 700+ через несколько минут падают до 500, и все довольны.
[Исправлено: Rime, 05.05.2014 в 10:55] |
20
Регистрация: 01.04.2013 Последняя активность: 12.12.2025 07:04
Сказал(а) спасибо: 1784
Поблагодарили: 4013 раз(а) в 2078 сообщениях
Фонарь вполне отчётливо напоминает армитек конечно, но тут скорее вопрос цены.
Если что то в районе $100, то и внимания не стоит за недобренд, если $50, совсем другое дело. Но режимы реально неудачные для налобника. Они с этими турбами задрали уже в конец, чего там выжимать то из налобника, жар как от паяльника и севший по быстрому аккумулятор? Можно ещё было бы понять если 2х18650 в питании, да и то.. Я бы предложил 400, 150, 70, 0.5 Оголовье заинтересовало, на качество реальных бы взглянуть.
