Вернуться   Форум FONAREVKA.RU Торговая площадка Производители/Дистрибьюторы/Дилеры фонарей и аксессуаров SKILHUNT
Просмотров в теме 3302   Ответов в теме 1   Подписчиков на тему 1   Добавили в закладки 0
Старый 29.04.2014, 07:49 Автор темы   1
Аватар для skilhunt
Последняя активность: 10.06.2025 04:25
Поблагодарили: 159 раз(а) в 53 сообщениях
Popcorn New release, SKILHUNT DS15 EDC 240lumens flashlight
Hello Everyone,
More details
LED: CREE XM-L2
Max output: 240Lumens
Max runtime: 120 h
Max beam distance: 85 m
Max peak beam intensity: 1800 cd
Waterproof: IPX-8
Impact resistant: 1.5 Meter
Battery: 1x14500 or 1x AA Ni-mh or Alkaline
Rated Range: 0.9V ~ 4.2V
Dimension:
Length 91mm/3.58inch
Head diameter 24mm/0.94inch
Body diameter 22mm/0.86inch
Weight: 51g / 1.8oz (without battery)
Accessories: Clip, lanyard, magnet replace O-ring, Operator’s manual, Warranty card, Spare O-ring
Optional Accessories: Headband
Features
1. Super bright & lastest CREE XM-L2 LED, High-performance, High-efficiency and energy conservation.
2. Durable aluminum vacuum plating reflector, Efficiency reflection, perfect beamshot, excellent structure and temperature resistance.
3. Toughened ultra-clear glass lens with 99% luminousness anti-reflective coating.
4. Rugged indestructible aluminum body with anti-scratching type III hard anodization.
5. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity.
6. Side switch button to transferring mode user-friendly interface to adjust output.
7. Four output levels and strobe, suitable for different environment.
8. Wide input range provides more choices of batteries.
9. Automatic memory function, remember bast used setting and can be preset to specific output mode for instant access.
10. Reverse polarity protection, to protect from improper battery installation.
11. Low-voltage prompts function, the light will flash when the battery is low, remind user replace the battery on time.
12. Engineered anti-slip knurling for a tightly firm grip.
13. Dual recoil absorbing springs, battery impact resistance.
14. Tail stand as a candle-light.
15. Tail hand hole design for lanyard use, to prevent accidental dropping.
skilhunt вне форума   Ответить с цитированием Вверх
_rider (29.04.2014)
Старый 29.04.2014, 08:06   2
ilyasov1
Сказал(а) спасибо: 948
По умолчанию Re: New release, SKILHUNT DS15 EDC 240lumens flashlight
see headlamp, TIR optics. Interesting review of the lantern.
SC51, Н600F, H602w, H600w mkII, Niteye JA10, ThruNite TN10 (NW), Jetbeam BC40, Bronte X03 (NW), Bronte RA04 (NW XM-L), Tank007 e09, Xeno E03, Olight S20
ilyasov1 вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09012 секунды с 15 запросами
