Просмотров в теме 2386   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 07.04.2014, 21:34 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Keeppower IMR18650 2500mAh (Black) 2014
Official specifications:
  • Min Capacity: 2400mAh
  • Typical Capacity: 2500mAh
  • Normal Voltage: 3.6V/3.7V
  • Cell: Made in Korea
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 20A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Dimension: (D)18.50mm*(H)66.50mm
  • Weight: Max. 49.0g
For once I did not use my 2.8 volt cutoff, but discharged down to 2 volt (This is the lower limit for these batteries).
The battery has no problem delivering 20A.
Conclusion
The battery can be discharged down to 2 volt, but the voltage does compare favorable to other LiIon batteries with a higher end voltage. Using a cell from LG I will call this a very good high current battery.
Notes and links
[Исправлено: HKJ, 10.04.2014 в 19:11]
Alex TG (08.04.2014), vvvoland (07.04.2014), WallE (07.04.2014), Сумской (07.04.2014)
Время генерации страницы 0.08418 секунды с 15 запросами
