4068
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Keeppower 18650 3200mAh (Black) 2014
![]() Official specifications:
![]() This is the highest capacity cell with 4.35 volt at the current time, but due to the protection the mAh is to low. ![]() ![]() ![]() ![]() ![]() The discharge curves does not looke very nice, but that is not due to any problem with the cell, it is because the protection has intefered with the charging. It can also be seen that the protection trips after some time at 7A. ![]() ![]() ![]() ![]() ![]() ![]() Here it is obvious that one cell stops charging, before the other and probably neither of them is fully charged (The voltage drop when the charge current stops looks to large). Test with 4.3 volt charging Reducing the charge voltage slightly gets around the problem with the proction. ![]() ![]() The difference between 4.3 and 4.35 volt charging is minimal. This time the curves look fine. ![]() ![]() ![]() ![]() ![]() ![]() Both cells is fully charged here. Test with 4.2 volt charging ![]() Using a normal 4.2 volt LiIon charger does cost capacity, about 250mAh compared to 4.3 volt. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Conclusion Being based on LG cells, it is good batteries, but with the slightly low protection voltage they do not give the full benefit of the higher voltage. Notes and links The batteries was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Сказал(а) спасибо: 324
защита конечно подпортила. емкость на 4,35 меньше чем у незащищенного lg18650d1.
http://lygte-info.dk/review... |
