2310
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Sibeile IMR18650 1600mAh ft (Black) 2014
![]() Official specifications:
![]() This is a high current battery and as usual for this type of battery the capacity is at the low end. ![]() ![]() ![]() ![]() ![]() There is good match between the two cells and they has constant capacity up to about 20A, this is good. The max rating of 30A is probably only for pulse load. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion This battery is designed for high current and has a good performance up to 20A, below 10A there are batteries with more capacity. I will rate it as acceptable. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
