Просмотров в теме 29683   Ответов в теме 49   Подписчиков на тему 7   Добавили в закладки 0
Старый 08.02.2014, 16:09 Автор темы   1
Аватар для candle lamp
Последняя активность: 09.06.2017 16:17
Сказал(а) спасибо: 4
Поблагодарили: 403 раз(а) в 87 сообщениях
Ooo SupBeam Rechargeable Thrower K50 V2 [XM-L2 U2, 4x18650] Review
The K50 V2 is a new high-output "rechargeable thrower" flashlight from SupBeam that runs on 4x18650 cells. It seems the light has good features of K40 and X40. So I can say the K50 V2 is the highly upgraded light of the K40.
The K50 V2 sent to me came in the nice case. with metal hinges and closing flaps. Inside were the light, user manual, warranty card, USB charging cable, AC/DC adapter with USB interface, car charger with USB interface, extra o-rings, tailcap rubber switch boot, lanyard, holster. The case is larger than the K40 that I reviewed.
Manufacturer Specifications from SupBeam website & user manual:
• LED : Cree XM-L2 LED with lifespan 20yrs of runtime
• Lumens : Max 1610 lumens
• General mode : Level 1 (Min.)~Level 6 (Max.)
• Flashing mode : Strobe
• Dimming mode : Magnetic ring
• Working voltage : 10V - 17V
• Max Runtime : 3,100 hr
• Max beam distance : 760m
• Peak beam intensity : 144,400lux (1 m distance)
• Impact resistant : 1.2m
• Waterproofing grade : IPX8 standards, 2m
• Material : Aircraft grade aluminum body structure
• Premium type III hard anodized anti-abrasive finish
• Reflector : Ultra-clear tempered glass lens with anti-reflective coating
• Lens : Ultra-clear tempered glass lens with anti-reflective coating
• Size : 203.5mm (length) x 90.2mm (bezel dia.) x 52.5 (body dia.)
• Weight : 564g without battery
• Battery : 4x18650 Batteries
• Momentary forward click tactical switch
• Strobe mode for tactical and emergency use
• Highly focused beam for maximum distance
• Tactical knurling for firm grip
• Streamlined body design
• Mechanical reversed polarity protection design for battery carrier
• Intelligent highly efficient circuit board design for max performance and long run time
• Board design for max performance and long run time
Notice : The above mentioned parameters (tested with three 3400mAh batteries) are approximate and may vary between flashlights, batteries, and environments.
The hard (type III) anodizing is a slightly glossy black, with no chips or damage on my sample. The labels on the body are clear, bright white against the black background. There is a label mark on the control ring that lines up with the labels on the head.
The light has mainly 3 parts (i.e. head, battery tube and tailcap), and there is a battery carrier in the tube.
The light has a flat bezel ring and a red waterproof o-ring between the bezel ring and reflector. There are a lot of cooling fins on the head. The head base of the light has a positive contact spring to contact with the positive contact of the battery carrier. The light can roll fairly easily as there is no indented flats in the head help limit that somewhat.
The light uses a ultra clear tempered lens with anti-reflective coating. The purple hue is reflected on it. The K50 V2 has a larger head than K40 and uses a cool white XM-L2 U2 1A emitter. It is perfectly centered in the bottom of the reflector cup. The large and deep aluminum reflector is very nicely finished. I would expect more excellent throwy beam than K40.
The first distinctive aspect of the light is the control ring, located just below the cooling fins. All six constant output switching including Standby and Strobe is controlled entirely by the control ring. The light has ten slight indents on the control ring to help with feel. There is a white label mark (▼) on the control ring that lines up with the labels on the head. The individual six constant output levels are not labeled on the head, but there is a graded output arrow () which shows the direction of the output levels. There are firm detents at each level, with a slight click. So you may need to count detents to figure out what output level you are set to. Note that all labels and marks on the K50 V2 are much more clear and whiter than K40.
The total traverse of the control ring is about 165 degrees of the light that is the same as K40. The control ring action is smoother than K40 (i.e., its feel is nice, smooth, but neither loosen nor stiff).
There is a positive contact surrounded by black plastic on the front of the battery carrier.
Also you will see the another contact point surrounded by inner contact rim and outer rim on the rear of the battery carrier, in addition to the center contact. Those contacts are the positive contact which is the input port for 5V charging, and the negative contact for the battery carrier respectively.
The light uses a metal battery carrier that holds 4x18650 cells in series. It is sturdy and well-made. The positive contact plate is very slightly raised, and the negative contact spring has good elasticity in the carrier. So all types (i.e., true flat-tops, wide and small button-tops) of 18650's work fine. Longer & wider cells may be somewhat tight, but my protected high capacity (2600~3100mAh) cells all fit. You should insert the battery carrier in one direction into the battery tube (i.e., it's not reversible) as shown above. You, however, don't need to worry about that too much, as the battery carrier has the physical reverse polarity protection. But you should be careful to insert the 4x18650's into the battery carrier in the correct polarity. (i.e., the battery carrier has the same features and orientation as the X40).
As you see the fully loaded battery carrier with unprotected & protected 18650 cells, I don't have any issues to insert my shortest & longest 18650 cells into the carrier. Thanks to the very slightly raised positive contact plate, there's no catch on the heatshrink on the flat cells when removing them. But it's easy to first depress the cells towards the negative spring before removing them. My cells with wider dia. didn't have difficulty when inserting or removing from the battery tube. The battery carrier introduces little rattle if you shake the light laterally when it's fully loaded with 18650's unprotected. But no rattle with the protected 18650 cells installed in my sample. Note that only 4x18650 li-ion cells are supported in the light (i.e., multiple CR123A or RCR123A are not supported, due to 10~17V working voltage range).
Mostly the battery tube continues the cylindrical shape with four flat and long rectangular surfaces. The manufacturer, model name with serial number are on the battery tube.
Screw threads are good quality square-cut. Note that both male & female threads on the head & tube are anodized for head lock-out. They are smooth with no cross-threading or squeaking on my sample.
Unlike the K40 and X40, there's no knurling on the battery tube. Instead, the body is covered in a slightly bold checkered portions. It's slippery when using the light with wet hands. I would have hoped better knurling on the tube, similar to K40 and X40, that is of fairly high aggressiveness.
The another distinctive aspect of the light is a built-in charging port for 4x18650's based on a magnetic dock. You can see two metal circular contacts and the tiny LED indicator for battery power status. Inside the battery tube, there are three contact springs (i.e., middle, inner, and outer spring) which are connected to the three same positioned contacts of the battery carrier.
The switch is the forward click switch which allows the light to be momentarily activated by half-pressing the switch while not affective the mode changing which is completely controlled by the control ring on the head. The switching travel is slightly longer than average, with strong resistance and provides audible click when engaged.
The charging device consists of AC/DC adapter with USB interface, car charger with USB interface and USB charging cable. The AC/DC adapter and car charger have the LED power indicator.
Like the X40, you can use one of the three charging device to charge 4x18650's in the light.
The USB charging cable attaches to the external tailcap contacts directly through a magnetic connection, like the X40. I feel this magnetic pull is somewhat strong similar to the X40. The LED indicator shows you two charging status. It will illuminate constant red under normal charging conditions. When charging is complete, it turns to constant green. The initial charging current is 500mAh (i.e., total current is 2A), and the termination current is 10% of the initial charging current. The light uses the same parallel charging way as X40.
I did a simple charging test with VicLite 18650 (2600mAh) protected and Panasonic NCR 18650 (3100mAh) unprotected cells in the light, using the AC adapter. The resting voltage before charging and after charging were as follows :
I noticed that the resting voltages for the cells, once the LED indicator went green, were 4.18V~4.22V, which is reasonable and a bit higher than X40. I noticed the indicator back and forth between red and green until the cells are fully charged. I expect the charging time will be longer on the USB port than the AC adapter.
The small LED indicator when the light is on or in standby mode shows four battery status. According to the manual, it will be green steadily when the battery capacity is more than 50%. It will be orange when the battery capacity is 30~50%. In case of red, the battery capacity is 10~30%. The red indicator will blink when the battery capacity is less than 10%.
But you will not see the orange indicator when use, because the resistance and the capacity of the battery is different. Actually I noticed by accident the orange indicator just for 1~2 seconds during the runtime test on max. output (L6). Also the indicator goes off and the light flickers shortly three times every 25 seconds when the battery is very low.
You can attach the lanyard came with the light as shown above. I found it's easy to attach the lanyard without a split ring. The light can tailstand with the lanyard attached.
From left to right, VicLite 18650 protected, SupBeam K40, SupBeam K50 V2, Olight M3X, Crelant 7G5CS, Armytek Barracuda.
The head size & body weight excluding battery of the following lights are as follows :
K40 - 76.5mm / 505g, K50 V2 - 90.1mm / 644g, M3X - 63.2m / 276g, 7G5CS - 64.0mm / 336g, Barracuda - 64.0mm / 392g. This is one of the largest reflectors I have ever seen.
Measured Dimensions & Weight
K50 V2 comes with a nice nylon holster with a velcro strap on the head. The light fits in the holster head-up only. I would rather the manufacturer did make the cover a bit longer (1~2cm).
The light is a bit big size, due to the large head, but with a proper weight to manage it. The operating the control ring with two fingers (i.e., thumb and index finger) is relatively easy, but difficult with the thumb only. The build feels solid and well-made. Handling & balance of the light are good like K40 and X40. The overall build quality is very high.
User Interface
On-off is controlled by the tailcap forward switch and output switching is controlled by the control ring in the head. Turn the light on-off by the tailcap clicky – press for momentary, press and release (i.e., click) for constant on.
There are six constant output levels, stanby, and strobe. Change output modes by turning the control ring in the head. Arranged from left to right (with the head facing forward) in the following order. L1 (min. output) -> L2 -> L3 -> L4 -> L5 -> L6 (max. output) -> standby -> strobe.
No light is produced on standby, but a small current will be drawn to allow the circuit to respond to a ring turn. I recommend you store the light clicked-off at the tailcap, or locked-out by a head twist.
PWM
The light shows no sign of PWM at any output levels. They say the light is actually current-controlled on all modes. I notice there is no buzzing sound on my sample.
Runtime
1. K50 V2
Runtime performance is very good and flat regulation is evident on L6 I tested. As with the K40, the light steps down slightly after around one mins of runtime (i.e., K50 V2 settles around the 88% output mark of the initial output for the runtime with cooling). I could see the light dropped down to a very low output similar to moonlight (L1), instead of completely shutting off when the battery protection circuit kicked in, and it flickered shortly three times every 25 seconds at a very low output for low battery warning, similar to the K40.
The overall runtime is longer with the greater capacity cells, as expected.
The runtime for 10% output of max. output (L6) for various 18650 is as follows :
1) 4xVicLite 18650 (2600mAh) protected : 111 min.
2) 4xPanasonic 18650 (3100mAh) unprotected : 124 min.
2. K50 V2 & K40
The K50 V2 on max. output is almost 27% brighter than the K40 in both intial output and stepped-down output continuously before hitting the built-in battery protection circuit shut-down. The overall runtime between the lights is almost the same.
The runtime for 10% output of max. output (L6) for the lights is as follows :
1) K50 V20 on 4xVicLite 18650 (2600mAh) protected : 111 min.
2) K4 4xVicLite 18650 (2600mAh) protected : 116 min.
From the above runtime graph, I speculate about the reason why they use 4x18650 battery source instead of 3x18650's. I like it very much.
3. Runtime graph enlarged from the above 2
The K50 V2 steps down slightly after 60~69 secs of runtime. The light remain perfectly stabilized throughout the remaining max. output run.
This seems to be a timed drop-down considering the overheat protection, not a thermal sensor feature.
Beamshot
1. White door beamshot (about 50cm from the white door) on Max. output
- ISO100, F/3.5, 1/200sec, Auto white balance
- ISO100, F/3.5, 1/500sec, Auto white balance
- ISO100, F/3.5, 1/800sec, Auto white balance
- ISO100, F/3.5, 1/1250sec, Auto white balance
The overall beam profile is very smooth and clean with noticeable flaws and has an intensely small hot spot. The spill beam is pretty wide and it is rather dim relative to the hot spot. The beam is a cool side.
- ISO100, F/3.5, 1/400sec, Auto white balance
I think the six output levels are well spaced. The K50 V2 has very good lower output level L1 (closer to a moonlight).
2. 55m Outdoor Beamshot on Max. output
- ISO100, F/2.8, 1sec, Auto white balance
3. 60~65m Outdoor Beamshot on Max. output
5. 130m Outdoor Beamshot
6. 155, Outdoor Beamshot
This light is a new throw king with single XM-L2 light I've tested to date that is pretty impressive.
[Исправлено: candle lamp, 08.02.2014 в 16:17]
candle lamp вне форума   Ответить с цитированием Вверх
Поблагодарили: 13 раз(а)
Admin (09.02.2014), crus (08.02.2014), Khii! (22.12.2014), LEV-UA (10.02.2014), nokiaf (09.02.2014), nurlanchm (08.02.2014), PASHA (08.02.2014), Slavkin (08.02.2014), surf839 (09.02.2014), Tim_ON (10.02.2014), vvvoland (09.02.2014), WallE (08.02.2014), zebottendorf (11.02.2014)
Старый 08.02.2014, 17:09   2
PASHA
вечный n00b
Аватар для PASHA
Сказал(а) спасибо: 5257
По умолчанию Re: SupBeam Rechargeable Thrower K50 V2 [XM-L2 U2, 4x18650] Review
Бомба
Старый 09.02.2014, 13:13   3
Exploder
смотритель маяка
Аватар для Exploder
Сказал(а) спасибо: 257
ну и что лучше? этот девайс или TN32 от трунита
Старый 09.02.2014, 14:04   4
surf839
Аватар для surf839
Сказал(а) спасибо: 2113
Бомба
бомба то бомба,но тн 31 или тн32 по характеристикам такой же,но более утонченно сделан,этот грубоват,ну по моему мнению конечно.
surf839 вне форума   Ответить с цитированием Вверх
Старый 09.02.2014, 14:22   5
PASHA
вечный n00b
Аватар для PASHA
Диаметр рефлектора больше, ну и 4 акб против 3х. В метрах плюс минус тоже. Но это из коробки. Посмотрим что Walle из него выжмет )))).
[Исправлено: PASHA, 09.02.2014 в 14:26]
Старый 09.02.2014, 17:49   6
WallE
Аватар для WallE
Сказал(а) спасибо: 1449
для меня, этот однозначно лучше чем ТН31-32, ибо
все равно и первый и второй фонарь заготовка, но в тн32 уже вкачали 6.5 ампер и большего из него не выжать.
Exploder (10.02.2014), vvvoland (10.02.2014)
Старый 10.02.2014, 04:24   7
66magic99
Аватар для 66magic99
Последняя активность: 21.12.2021 20:15
Сказал(а) спасибо: 669
Поблагодарили: 114 раз(а) в 86 сообщениях
vn-модификация к50 выдаёт 670ккд.
66magic99 вне форума   Ответить с цитированием Вверх
Старый 10.02.2014, 09:45   8
Exploder
смотритель маяка
Аватар для Exploder
Посмотреть сообщение Сообщение от 66magic99 :
Это конечно круто... Но есть небольшой нюанс.. Подавляющее большенство людей не будет ничего разбирать, перепаивать, не станет проводить операции на диодах и прочее. У людей нет запасных хмелей на случай провала, мультиметров, паяльных станций и представления о том, что именно перепаивать. Нет электротехнического образования и схемм драйверов. Мало кто сможет разобрать и собрать все это без попадания пыли и прочей дряни на отражатель и стекло. Да и стоимость в OVER 6000 заставляет трижды подумать перед вмешательством такого рода, тем более, что это влечет за собой потерю заводской гарантии..
Так что ждем бимшоты прожектора с 670ккд с нетерпением от тех кто может это сделать
Yurik (10.02.2014)
Старый 10.02.2014, 09:51   9
Посмотреть сообщение Сообщение от Exploder :
нюанс этот называется "я тут проездом"
Старый 10.02.2014, 16:00   10
Exploder
смотритель маяка
Аватар для Exploder
Нет, блин, я всю жизнь только и мечтал фанарики перепаивать тоннами и посты строчить тысячами Конечно я тут проездом! Так что колитесь какой дальнобой в стоке предпочтительнее SupBeam K50 или Thrunite tn32 (надежность и т.п) и я дальше поеду на рыбалку, в поход, в спортзал, на коньках покатаюсь или на санках с горки с друзьми ночью с вискарем и шашлыками. Я с большой долей вероятности не буду нифига апгрейдить до истечения гарантии на фонарь, а может и разобрать не смогу как голову у Fenix tk35...
dmitriy.moiseevich (11.02.2014)
Старый 10.02.2014, 17:37   11
crus
Последняя активность: 05.01.2018 02:18
Сказал(а) спасибо: 280
А еще лучше заказать кастом к50vn v2- и ничего паять не надо, все уже сделано за вас.
crus вне форума   Ответить с цитированием Вверх
Старый 10.02.2014, 19:06   12
66magic99
Посмотреть сообщение Сообщение от crus :
не носит он потребительского характера.
Старый 10.02.2014, 21:10   13
PASHA
вечный n00b
Аватар для PASHA
это что и где?
Посмотреть сообщение Сообщение от WallE :
Он наверн и SolarForce 1100 потенциально способен уделать?
Старый 10.02.2014, 22:53   14
DeathDoom
Recovery
Аватар для DeathDoom
Последняя активность: 12.09.2024 15:46
Сказал(а) спасибо: 57
Поблагодарили: 40 раз(а) в 22 сообщениях
уже это делает))
Petzl e+LITE. Sofirn SP36. Astrolux MF-01, C8. Convoy M2. Supbeam x40(xm-l2) в ремонте, Supbeam k40(xm-l2 dedomed, driver mod 6A), MTE H8-1S (xhp50.2), Trustfire x6(xm-l2 dedomed), Trustfire z6(xm-l2 dedomed), DQG EDC 18650 1-rst, Roche f6, Varta(4 Watt LED Camping Lantern 3D). Ну, и мелочевка.
DeathDoom вне форума   Ответить с цитированием Вверх
Старый 10.02.2014, 23:57   15
PASHA
вечный n00b
Аватар для PASHA
Посмотреть сообщение Сообщение от DeathDoom :
уже это делает))
обычный или дедомлено-овердрайвленный с Киевской фонаревки? =)
Старый 11.02.2014, 01:07   16
DeathDoom
Recovery
обычный к50 в2 перебивает обычный с1100, ну, и "необычные" позиционируются так же :-)
PASHA (11.02.2014)
Старый 11.02.2014, 08:03 Автор темы   17
candle lamp
Бомба
Why do you think the light is bomb?
Старый 11.02.2014, 10:44   18
PASHA
вечный n00b
Аватар для PASHA
Посмотреть сообщение Сообщение от candle lamp :
because of beam intensity, this parameter rather most important among throwers, imho. And I like it a kind of toilet plunger design. ))
By the way there are strong opponent - Fenix TK61
[Исправлено: PASHA, 11.02.2014 в 11:17]
Старый 11.02.2014, 10:53   19
66magic99
it's a figurative expression.
Старый 11.02.2014, 11:02   20
Exploder
смотритель маяка
Аватар для Exploder
Хлопці гарно пишуть, як Хамингуэй...
Время генерации страницы 1.16093 секунды с 16 запросами
