Просмотров в теме 2263   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 07.02.2014, 01:04 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Efest IMR26650 3000mAh (Red) 2014
Official specifications:
  • Weight: 95g
  • Length: 66.67 mm
  • Diamter: 26.21mm
  • Top: flat top
  • Bottom: non-procted
  • Typical Capacity: 3000mAh
  • Min capacity: 3000mAh
  • Maximum discharging current: 15A
  • Maximum charging current: 6.5 A
  • Maximum pulse discharging current: 60A
  • Resistance: 13±2 mOhm
  • Battery WH: 125WH\Kg
  • Discharge cut-off voltage: 2.5V
  • Voltage: 3.8V
  • Full Charge voltage: 4.2V
  • Monthly Self-discharge rate: < 0.5%
  • Temperature range: Discharge: -20~+60 ºC, Charge: 0~45 ºC
This battery is rated as a high current type.
The batteries can handle up to 20A, but does heat up at 15A and 20A. It is nice with nearly constant capacity at any load.
The 15A rating is fine for it.
Conclusion
These batteries has good performance up to 10A, but it is possible to find 26650 with lower capacity, but considerable better high current capability.
It will rate it as an acceptable battery.
Notes and links
The battery was supplied by Efest for review.
Alex TG (07.02.2014), nurlanchm (07.02.2014)
Время генерации страницы 0.10242 секунды с 15 запросами
