2413
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Sibeile IMR14500 700mAh (Black) 2014
Button top version ![]() Official specifications:
![]() The is the button top version of the cell. ![]() ![]() ![]() ![]() ![]() Good tracking between the cells and also constant capacity at any load, this looks good. ![]() ![]() ![]() ![]() ![]() ![]() Flat top version ![]() Official specifications:
![]() The is the flat top version of the cell. ![]() This version also has good tracking between the cells and also constant capacity at any load, this looks good. I expect they are using the same cell, i.e. they must have the same performance. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Conclusion The batteries has a good capacity for IMR batteries, even though it is lower than rated. The performance is also good, even at much higher current than they are rated for. There is a very small difference between flat top and button top, the button top increases the resistance slightly. I will rate this battery acceptable. Notes and links The battery was supplied by Sibeile for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Comparison to other LiIon batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Admin (29.01.2014)
