Просмотров в теме 2758   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 25.01.2014, 20:58 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Keeppower IMR18650 2900mAh (Black) 2014
Official specifications:
  • KeepPower 18650 3.6V/3.7V 2900mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 2750mAh
  • Typical Capacity: 2900mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 10A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Dimension: (D)18.50mm*(H)66.50mm
  • Weight: 46.0g
This is a high capacity high current battery
The two cells has very good tracking and only a minor capacity loss when the current is increased.
Conclusion
There are cells with higher voltage at high current, but none other with this much capacity.
With a Panasonic cell inside it is a very good battery, that can deliver a lot of current.
Notes and links
The battery was supplied by Keeppower for review.
[Исправлено: HKJ, 26.01.2014 в 13:48]
Admin (25.01.2014), Сумской (26.01.2014)
Время генерации страницы 0.07952 секунды с 15 запросами
