Просмотров в теме 2752   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 09.01.2014, 23:20 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Keeppower IMR26650 3500mAh (Black) 2014
Official specifications:
  • Brand Name: KeepPower
  • Type: Li-Ion
  • KeepPower IMR 26650 3.6V/3.7V 3500mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 3400mAh
  • Typical Capacity: 3500mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 20A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Flat top: Yes
  • Dimension: (D)26.50mm*(H)67.000mm
  • Weight: Max. 93.0g
This battery is rated as a high current type.
The two batteries has different capacity and being unprotected this makes them very bad for usage in series.
The batteries can handle up to 20A, but does heat up.
Conclusion
These batteries are acceptable for single cell use, but due to the difference in capacity not for usage in series.
The high current performance is acceptable, but it is possible to find 26650 with lower capacity, but considerable better high current capability.
Notes and links
The battery was supplied by Keeppower for review.
Admin (12.01.2014), crus (10.01.2014), Сумской (11.01.2014)
Время генерации страницы 0.08313 секунды с 15 запросами
