Просмотров в теме 2878   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 09.01.2014, 17:55 Автор темы   1
Последняя активность: 25.12.2014 05:34
Сказал(а) спасибо: 4
Post Nitefighter BT40 Cree XP-G R5 1600LM Bicycle light
BT40 is a wide beam and high brightness mountain bike front light. Utilizing four Cree XP-G(R5) LEDs, four brightness modes, max output 1600-lumen. It including 7.4V 4400mAh BAK rechargeable li-on battery,more than 3hrs on high output. BT40 is the ideal illumination gear for mountain biking, touring, commuting, etc.
Features
Utilizes four Cree XP-G (R5) LEDs, max 1600lumens output;
Powered by four BAK 18650 rechargeable Li-on batteries,7.4V 4400mAh ;
Uses high quality optical lens with a wide beam angle;
4 brightness levels;
Digitally regulated output-maintains constant brightness;
Overheat protection function;
4-Color & 5-Mode LED Indicator displays remaining battery capacity;
Quick to attach and detach using O-ring mounting straps sized for 20mm-35mm handlebars;
Made of durable aircraft-grade aluminum;
Premium Type III hard-anodized anti-abrasive finish;
42mm(Diameter)x49mm(length);
113g(excluding batteries and accessories)
Packgae Contents
Headlamp;
Battery Pack;;
O-ring Mounting Straps;
Extension Cable;
Helmet Mount;
Charger;
Cable Tie;
User Manual;
FLARE LIGHT ENTERPRISE LIMITED
Dongguan Lumingear Lighting Co.,LTD
Tel: 0086-769-87935366
Fax: 0086-769-87939365
Website: www.nitefighter.com
Email: sales@nitefighter.com
Alibaba Website: http://lumingear.en.alibaba...
Nitefighter вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.07203 секунды с 15 запросами
