Просмотров в теме 2789   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 01.12.2013, 21:48 Автор темы   1
Аватар для 880arm
Последняя активность: 28.07.2014 00:17
Поблагодарили: 35 раз(а) в 9 сообщениях
По умолчанию SureFire E2L-A Outdoorsman - Review, Runtime, and beamshots
The SureFire E2L-A Outdoorsman is the latest member of the SureFire E2L series of flashlights. Designed to provide extended runtime, the dual-output E2L-A is powered by two 123A lithium batteries and is rated to provide 5 lumens for 67 hours in low mode and 125 lumens for 7.25 hours in high mode. As with previous versions of the E2L, the new Outdoorsman utilizes a Total Internal Reflection (TIR) lens to focus output and is controlled by a pushbutton tailcap.
The E2L-A always comes on in low mode first, with high mode selected by an additional press or click of the tailcap button.
The E2L-A features aerospace aluminum construction and uses the same body and tailcap design as previous versions. The most notable differences with the new version are the addition of SureFire's 2-way pocket clip and the completely redesigned KE2 head.
The E2L-A can be disassembled into its major component parts which are completely interchangeable with other SureFire E-series lights.
The 2-way clip allows the light to be carried in either bezel up or bezel down positions.
SureFire E2L-A Performance
The E2L-A produces a broad center hotspot which can easily reach beyond 60 meters. This hotspot is surrounded by an extremely wide spill beam which allows peripheral vision out to around 20 meters.
The beam has a slightly warm and greenish tint which is most noticeable when illuminating a white surface or comparing the light to a cool white LED. In actual usage the greenish tint is not nearly as noticeable, especially when used outdoors.
(30 meters to swing)
(20 meters to swing)
(10 meters to swing)
Additional beamshots and side-by-side comparisons with several other lights can be found in the full SureFire E2L-A Outdoorsman review at FlashlightlightGuide.com.
Runtime
The E2L-A provides extremely stable output for the first 6 hours of continuous operation, followed by a period of declining output.
The E2L-A can also be used with SureFire's new F04-A, F05-A, and F06-A diffuser and filters.
Additional photos and beamshots can be seen in the Mini-Review of the SureFire Diffusers and Filters.
Conclusions
The E2L-A Outdoorsman is a nice upgrade over prior versions for users who want a little more output or a broader beam. Designed with efficiency in mind, the E2L-A will not be as impressive, from the standpoint of sheer output, as other higher powered lights but it provides a very respectable level of output for a long period of time.
Strengths
  • Very useful beam with good reach and spill
  • Excellent runtime with 6 hours at full output
  • Parts compatibility with other E-series lights
  • Addition of 2-way pocket clip
Concerns
  • As this is an "outdoors" type of light, it seems odd there is no lanyard attachment point
Thanks for reading!!
FlashlightGuide.com - ******** - *******
880arm вне форума   Ответить с цитированием Вверх
Alexandr8253 (03.02.2014), Светлячок (01.12.2013)
Время генерации страницы 0.07909 секунды с 15 запросами
