2341
Регистрация: 22.04.2012 Последняя активность: 18.02.2016 02:43
Поблагодарили: 146 раз(а) в 55 сообщениях
Rather than a full in-depth review, this is a brief 'Performance Review' of the Spotlightgear lights.
![]() From left to right with brief summary: Shifter 4.0 (4xAAA) – Forward-clicky, 3-mode (High, Low, Strobe), Flood to Spot zoom. Shifter 1.0 (1xAAA) – Forward-clicky, 1-mode (High, Low, Strobe), Flood to Spot zoom. Rescue (12v rechargeable – fits into lighter socket) – Twist on, 2-mode (High, Flash) Turbo (12v rechargeable – fits into lighter socket) – Twist on, 1-mode Spark (4xbutton cell) – Twist on, 1-mode I have run the lights through the same technical testing I normally carry out for a full review, and am presenting the results in a more concise way so you can easily see how they actually perform. Batteries and output: To measure actual output, I built an integrating sphere. See here for more detail. The sensor registers visible light only (so Infra-Red and Ultra-Violet will not be measured). Please note, all quoted lumen figures are from a DIY integrating sphere, and according to ANSI standards. Although every effort is made to give as accurate a result as possible, they should be taken as an estimate only. The results can be used to compare outputs in this review and others I have published. Unfortunately I can't report on the Spark's performance as due to an undersized o-ring on the one I had, the head went missing in action… ![]() The runtime graph shows the output traces for both the Shifter 4.0 and 1.0 running on maximum output and with a cooling fan. The Shifter 4.0 has an unusual initial building up of the output up to around 375lm before dropping to a long run at 80lm. The Shifter 1.0 has a much more predictable general decline. ![]() Taking a closer look at the first part of the trace, you can see the Shifter 4.0's output building up to a maximum at 3 minutes from switch on. ![]() The trace for the Rescue and Turbo looks quite rough due to the low output levels showing the resolution of the measurement. The rescue runs until it cuts out whereas the Turbo dims down to unusable output levels but doesn't go out suddenly. ![]() A few additional comments: The 12v Rechargeable lights have a range of accessories including: A 12v USB charger - Very nice addition that makes the 12V range much more practical as it can be recharged with a computer or any other USB socket. Headband – converts the light into a head torch. Unfortunately due to the positioning of the light, the outer spill falls onto the side of your face. Clip - with rubberised feel finish, making a pocket clip or 'baseball cap headlamp' 12V lanyard/keyring - The rubber boot fits very securely allowing you to wear the light as a necklace. The Turbo itself is a nice compact size and once in the lighter socket almost disappears. Although it has a charging indicator it has no fully charged indication. The beam dims quite rapidly and switch operation feels a bit clunky. A step up in size, the Rescue has a good beam with broad diffuse hotspot. The rotating bezel/switch feels as if it might pop off when switching on and off, but has not done so. The strobe function adds to the versatility, especially as a cycling 'visibility' light. The rescue does have a charging and fully charged indicator. The Shifter 4.0 looks very similar to some other brand with zoom function which also use a hybrid reflector/lens system (RLS). This RLS works very efficiently with minimal loss of total output even when zoomed to a tight spot (with 85.9% of the flood output). Now one of my firm favourites, the Shifter 1.0 also uses the RLS zoom head to allow a small 1xAAA to focus its beam. The forward clicky operation and simple no-memory interface makes for a very usable light. Due to the size of the head, the zoom is less efficient when on spot (having only 48.75% of the flood output), but this is forgiven considering its very small size. A high of 111lm and a good hour of runtime around 70-80lm makes it a good performer as well. ![]() Test samples provided by Spotlightgear. |
crus (29.11.2013)
