Просмотров в теме 4100   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 28.11.2013, 09:56 Автор темы   1
Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
По умолчанию Fenix ARE-C2 Charger and NiteCore HC50 Headlamp in stcok--wallbuys
Fenix ARE-C2 Intelligent LCD Battery Charger for 4 x 18650 / 26650 / AAA / 16340-Black
Link:http://wallbuys.com/Product...
Description
ARE-C2 is an advanced multi-charger compatible with broad spectrum of Li-ion and Ni-MH rechargeable cell sizes and capable of charging four different rechargeable batteries simultaneously while the LCD display keeps you informed with readouts of voltage and charging status. Utilizing our exclusive accelerated charging technology, it takes only three and a half hours to fully charge four ARB-L2 (2600mAh) 18650 rechargeable batteries.
Product Type: Battery Charger
Brand: Fenix
Model: ARE-C2
Color: Black
Material: Plastic housing
Quantity: 1
Compatible Batteries: 18650 / 26650 / 16340/ 14500 / AA / AAA / C
Battery Quantity: 4
Input Voltage: AC 100-240V,50/60Hz,max.500mAx4
DC 12-24V,max.2000mA
Input Power: 4.2V/1.5V 1000mA x 4 / 500mA x 4
Plug Type: US plug
Other Features: 4 channels work independently
Intelligently recognize battery type and precisely choose the charging mode
Support car charger(not included car charing cable)
With LCD to display the charging state/voltage
Quadruple safety protection:short-circuit protection/reverse polarity protection/
overcharge protection/overcurrent protection
Operating Temperature: 0℃ - 40℃
Dimensions: 156x99.5x37mm
Packing List:
1 x Charger
1 x Charging Adapter(US plug)
NiteCore HC50 CREE XM-L2 T6 565LM 5-Mode Dual Light-Source White/Red LED Headlamp-Black(1x18650/2xCR123)
Link: http://wallbuys.com/Product...
Product Features
Material: Aluminum Alloy
Color: Black
Emitter Brand: CREE
Emitter Type: LED
Emitter BIN: XM-L2
Emitting Color: White/Red
Total Emitters: 1
Brightness: 565LM(manufacturer rated)
Runtime: 400h at lower mode(manufacturer rated)
Beam Range: 85m
Modes: White Light:Turbo(565LM)-High(350LM)-Mid(170LM)-Low(35LM)-Lower(1LM)
Red Light: 1.2LM,145h
Mode Memory: -
Switch Type: Side Clicky Switch
Lens: Coated mineral glass
Reflector: Aluminum Smooth/SMO Reflector
Circuitry: Constant Current Circuit
Voltage Input: 3.7-4.2V
Waterproof: IPX-8,underwater 2m
Special Features: Innovative single button two-stage switch is remarkably user-friendly (patented)
Power indicator secondary function displays battery voltage accurate to 0.1V
Light housing provides 90°vertical movement to eliminate illumination dead-zones
Application: Outdoor/Lighting/Hunting/Riding/Camping
Battery-Powered: 1x18650/2xCR123(not included)
Dimensions: 86(L) x 32(D)mm
Packing List: 1 x Headlamp
Nitecore P12 will arrive in wallbuys tomorrow, just pay more attention to : http://wallbuys.com/catalog...
[Исправлено: cherryzhou, 28.11.2013 в 10:07]
cherryzhou вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09114 секунды с 15 запросами
