Просмотров в теме 2389   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 13.11.2013, 23:19 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Kinoko IMR16340 700mAh (Gray)
Official specifications:
  • Size: 16340
  • Model: 16340IMR
  • Type: Li-Mn
  • Rated Capacity: 700mAh
  • Nominal Voltage: 3.7V
  • Lowest Discharge Voltage : 2.50V
  • Peak Voltage: 4.2V
  • Standard Charge : CC/CV ( max. charging rate 1.5A )
  • Dimensions: 16.45mmX32.99mm
  • Weight: 25g
  • Rechargable: Yes
  • Protected: Not Required for Li-Mn chemistry
  • Chemistry: Lithium Manganese Dioxide Li-Mn02
  • Discharge temperature range : -20°C--45°C
  • Charger temperature range : 0°C--45°C
  • Storge: 1year : -20°C--25°C, 3 months : -20°C—45°C, 1 month : -20°C—60°C
A IMR battery in CR123 size.
These batteries can deliver about 3A, this is a lot of current for this battery size. The capacity is not matched (They seldom are for 16340).
Conclusion
The performance is as expected for a IMR cell. I will rate these batteries as acceptable.
The difference between the cells means that it is best to avoid using the cells in series.
Notes and links
The batteries was supplied by Illuminationsupply for review.
Comparison to other LiIon batteries
Gary (13.11.2013)
Время генерации страницы 0.15959 секунды с 15 запросами
