Просмотров в теме 2230   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 07.11.2013, 22:43 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Kinoko IMR14500 750mAh (Gray)
Official specifications:
  • Brand: Kinoko
  • Size: 14500
  • Model: 14500 IMR
  • Type: Li-Mn
  • Rated Capacity: 750mAh
  • Nominal Voltage: 3.7V
  • Lowest Discharge Voltage: 2.50V
  • Peak Voltage: 4.2V
  • Standard Charge: CC/CV ( max. charging rate 1.5A )
  • Dimensions: 14.15mmX48.85mm
  • Weight: 25g
  • Rechargable: Yes
  • Protected: Not Required for Li-Mn chemistry
  • Chemistry: Lithium Manganese Dioxide Li-Mn02
  • Style: Button top (may require a magnetic spacer)
  • Discharge temperature range : -20°C--45°C
  • Charger temperature range : 0°C--45°C
  • Storge: 1year : -20°C--25°C, 3 months : -20°C—45°C, 1 month : -20°C—60°C
A LiIon IMR battery in AA size.
The high current capabilty is good on these cells.
The two cells does not have exactly the same capacity and without protection this makes them best for single cell usage.
Conclusion
This IMR cells has a good performance, I will rate it as a acceptable cell.
Notes and links
The batteries was supplied by Illuminationsupply for review.
Comparison to other LiIon batteries
Admin (07.11.2013), NazarSunrise (07.11.2013)
Время генерации страницы 0.08682 секунды с 15 запросами
