3445
Conquer the darkness in style. Покори темноты в стиле.: ROFLBulb: [Исправлено: LED flashlight, 21.10.2013 в 12:53] |
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 21.08.2025 18:32
Сказал(а) спасибо: 1744
На скрине свет как от фонаря на индикаторных диодах
Продам фонари Convoy S3 с разной TIR оптикой |
Регистрация: 24.02.2013 Последняя активность: 26.07.2025 11:59
Сказал(а) спасибо: 144
Свет - ладно. Но назвать ЭТО "small"...
If it is "small" for 18650, what will you call Olight S20? Micro or a keychain light?
Регистрация: 18.10.2013 Последняя активность: 21.10.2013 13:05
But Olight S20 only the half lumen of Crelant SD85.
"Runtime: High output at 3.0 A: 920 lumens for 115 minutes." means SD85 do not maintain full brightness trough whole runtime too. Flat 3A x 2 hrs = 6000 mAh, twice the capacity of best 18650 today.
Regardless of lumenage. SD85 has a common for "tactical" flashlight size, no way it is small for 18650 light. And in our age of step-downs one can have ~1000 ANSI lumens in a most compact 18650 host, dropping to ~200 after five minutes and showing "impressive" hours of runtime. Тыща люменов на два часа от 18650 - значит яркость роняется и сильно. Типичный тактический фонарь по размеру, ни в коем случае не "маленький". И в наше время тыщу люменов можно куда угодно засунуть - если на пять минут. |
Don't be one-sided and extreme, I think Led flashlight want to express that SD85 is one of the small flashlights, and the beam shot and beam distance of SD85 obviously much better. The picture may shows a bit exaggerated, but with this kind of design, it won't be bad. He didn't mean SD85 is the smallest but its powerful. S20 is good, i like its design, but different shape, different degisn has different usage, different power, etc. And we can't deny SD85 is good, and Crelant is becoming better and better.
And you did a good review on S20, thank you for sharing.
Okay, point taken. SD85 really is small flashlight compared to "common flashlight". Thought not smallest among it's class.
