2910
Регистрация: 10.05.2013 Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
This new model in stock now
price without coupon code :75$+free shipping our Coupon 11% off code :WALLBUYSALLMAGIC Link: http://wallbuys.com/Product... The Sunwayman D20A Gemini is an innovative new flashlight. The side by side, parallel battery configuration makes the D20A short and easy to carry. Dual light sources with white and red LEDs can effectively accommodate to just about any situation. The exquisite stepped dual-button design is intuitive and can even be used by feel in total darkness. A unibody design with the latest XM-L2 LED makes this high-performing light appealing and practical. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Features ● CREE XM-L2 and XP-E P2 LED, with a lifetime of up to 50,000 hours; ● Newest Stepped Dual-button Side Switch System, 6 output modes to select from: White Light Turbo: 258 Lumens (Automatically enter High mode after 3 mins continuous use to avoid overheat) High: 208 Lumens (2.3hrs.) Mid: 70 Lumens (9.3hrs.) Low: 4 Lumens (60hrs.) Strobe SOS Red Light High: 23 Lumens Mid: 10 Lumens Low: 4 Lumens Police Strobe Slow Flash ● Standby Current <100µA ● Constant current circuit, constant output ● Effective range of 126 meters ● Intensity: 4000cd ● Uses two AA batteries ● Working voltage: 0.9~3V ● White light uses high quality metal reflector, maintains great throw distance and spread with an ideal beam pattern; Red light uses high quality resin lens ● Dimensions: 21mm x 35mm x 102.5mm [Исправлено: cherryzhou, 18.10.2013 в 05:34] Причина: wrong type |
