Просмотров в теме 8025   Ответов в теме 13   Подписчиков на тему 3   Добавили в закладки 0
Старый 10.10.2013, 20:24 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Soshine RCR123 3.0V 650mAh (Black)
Official specifications:
  • Rechargeable Times:Up to 500 times
  • Type:Li-ion
  • Model:RCR123
  • Capacity: 650mAh
  • Output voltage:3.0V
  • Internal resistance:80
This battery is a not a normal LiIon battery, it uses ICR chemistry, but the output voltage is closer to IFR chemistry, this is because there is a diode inside the battery to reduce output voltage.
On Soshines website the charger voltage is specified as 3.6 volt, this is too low to get full capacity. I did my tests at 4.2 volt (3.6 volt nominal), 4.4 volt would probably have been better, but I will not go outside the specifications.
With this battery I am really missing a charger specification printed on the battery.
The two batteries does not match in capacity and without protection in the battery, avoid use them in series.
The battery does not have any protection, i.e. if it is over discharged once, it will be damaged and might also be dangerous.
The charge curve looks funny, due to the diodes and the low charge voltage.
Conclusion
The advantage of a diode is more capacity for a 3.2 volt battery, but I do not really believe it is a good idea, because the diode will generate heat at high loads and you can get real IFR batteries with about the same capacity (At least when you follow the charge specifications).
Notes and links
CR123A and rechargeable substitutes
Admin (17.11.2015), vorsmann (16.11.2015)
Старый 16.11.2015, 15:50   2
Mukcep
Enfant terrible
Аватар для Mukcep
Сказал(а) спасибо: 2868
По умолчанию Re: Test/Review of Soshine RCR123 3.0V 650mAh (Black)
Доброго всем времени суток!
А не можете подсказать, какая зарядка сможет нормально заряжать эти аккумуляторы?
А то Soshine H4 в режиме LiFePO4 их заряжать отказывается. Выдает ошибку зарядки.
Или такие аккумы только IMAX B6 или каким-нибудь похожим зарядить можно?
Старый 16.11.2015, 16:42   3
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Сказал(а) спасибо: 10202
Xtar VP2 http://lygte-info.dk/review... думаю хозяин обзора не будет против.
In Fino verytas
[Исправлено: vorsmann, 16.11.2015 в 16:48]
Mukcep (16.11.2015)
Старый 16.11.2015, 16:58   4
Mukcep
Enfant terrible
Аватар для Mukcep
Вот не совсем я уверен, что даже VP2 определит, ведь H4 тоже должен заряжать аккумы на 3.2V (для этого его и брал), а почему шлет по борозде - я не понимаю. Или алгоритм заряда для LiFePO4 отличается от Li-Ion (по логике должен быть схожим)?
Вообще за такую цену, которую просят за VP2, хотелось бы функцию разряда и измерение емкости аккумулятора. Или же я ошибаюсь и эти функции там есть?
[Исправлено: Mukcep, 16.11.2015 в 17:08]
Старый 16.11.2015, 18:45   5
barena
Аватар для barena
Последняя активность: 27.11.2025 14:45
Сказал(а) спасибо: 619
Посмотреть сообщение Сообщение от Mukcep :
В зарядном устройстве XTAR VP2 тип заряжаемого аккумулятора (напряжение зарядки) устанавливает пользователь с помощью ползунка-переключателя напряжения, возможные значения 3.6V (для Soshine RCR123), 4.2V и 4.35V (обозначены как 3.2V - 3.6V - 3.8V).
Это также относится к бюджетной версии (без дисплея) XTAR WP2H.
[Исправлено: barena, 16.11.2015 в 18:47]
barena вне форума   Ответить с цитированием Вверх
Mukcep (16.11.2015)
Старый 16.11.2015, 19:02   6
Mukcep
Enfant terrible
Аватар для Mukcep
Посмотреть сообщение Сообщение от barena :
Я в принципе видел переключатели, но просто не был уверен в том, что VP2 после пары минут ожидания так же не выдал бы мне BAE FAIL.
Я еще начинаю сомневаться - не обычный ли CR123 внутри торчит, а от Soshine только жестяная оболочка, потому что даже после 10 минут зарядки в любом режиме (на сей раз почему-то FAIL не выдает) ни один из параметров не меняется в принципе.
А еще 1600 руб. потрачено на H4 и покупать за 2000 еще и VP2 (и куда потом девать H4?) как-то жаба душит. Впору взять такой комплект: http://ru.aliexpress.com/it... и то дешевле выйдет и результат будет гарантированный
Тогда что уж там мелочиться - надо сразу Opus BT-C3100 закупать
[Исправлено: Mukcep, 16.11.2015 в 19:19]
Старый 16.11.2015, 19:47   7
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
опус в попус хстар своих денег стоит
[Исправлено: vorsmann, 16.11.2015 в 19:50]
Mukcep (16.11.2015)
Старый 16.11.2015, 21:27   8
Mukcep
Enfant terrible
Аватар для Mukcep
Ну за 2 рубля и выше хочется чтобы все и сразу: чтобы и разрядник встроенный, и измерение емкости при разряде, и функция повербанки, и чтобы напряжение заряда было и 1.5, и 3.2, и 3.7, и 4.2 и чтобы понадежнее
Старый 17.11.2015, 09:06   9
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
чтобы все и сразу
Это пока несбыточные мечты химияс разная
Старый 17.11.2015, 09:10   10
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
для измерения емкости есть масса разных модельных зарядок дорого но делает и меряет все.
Старый 17.11.2015, 16:32   11
Mukcep
Enfant terrible
Аватар для Mukcep
Если не сложно - можно пару конкретных зарядок-разрядок-тестеров, которые вам по нраву с готовыми лотками под 18650?
Под тот же много раз помянутый и икающий IMAX B6 холдеров я не нашел. Отдавать не такие уж маленькие деньги, чтобы потом что-то паять или перекручивать - да ну на фиг.
А можно все же немного подробностей?
Потому что аналогов я не нашел.
[Исправлено: Mukcep, 17.11.2015 в 18:01]
Старый 17.11.2015, 20:45   12
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Mukcep (18.11.2015)
Старый 19.11.2015, 11:32   13
Mukcep
Enfant terrible
Аватар для Mukcep
Ответ от Soshine по поводу зарядки сабжа с помощью H4:
I checked with our engineer, I'm sorry that H4 charger can't charge for 3.0V RCR123 battery. For this battery, need use our S5-Fe battery charger to charge it, hope your kind understanding.
Here is the link, please kindly check it: http://www.soshine.com.cn/a...
Старый 29.10.2017, 06:46   14
m.ix
Аватар для m.ix
Последняя активность: 29.07.2025 19:18
Поблагодарили: 33 раз(а) в 23 сообщениях
Сегодня купил фонарик и к нему акки
Soshine RCR123P 3V LiFePO4 16340
после распаковки тут же вставил
после погонял 4 раза под самый ноль
к счастью акк с защитно
но к сожалению с не заявленной ёмкостью.
заряжал на двух различных зарядках
одна на автомате
вторая - установил минимум 250 мА
акки фонариком разряжал, разрядились за полчаса
фонарик должен был светить по паспорту или слухам около часа
Nitecore EX11
Ремонтирую всё что работает на и от электричества.
m.ix вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.13408 секунды с 15 запросами
