4634
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Charger Xtar XP1
![]() Xtar made many good chargers, this is a new small charger. It has a single channel and can charger both LiIon and NiMH batteries up to AA size. ![]() It comes in a cardboard box with specifications on the back. ![]() I got the charger, a manual and a usb cable. ![]() The control panel has 3 leds and one button: 2 Leds to show selected current (0.25A or 0.5A). 1 leds to show charge status for the batteries (red=charging, green=done or no batteries). The button will select charge current, when power is connected and a long press will activate cycling with a NiMH (Not with LiIon). ![]() The power input is a micro usb connector, i.e. any usb power supply/charger can be used. ![]() Xtar has a special label on, that makes it possible to check for counterfeig chargers. ![]() The charger can handle both button top and flat top batteries, from 31mm to 52.8 mm (i.e. from CR123 up to AA size). The slider works very smooth. ![]() ![]() ![]() The charger can handle 52.8 mm long batteries, including flat top cells. (See my Small LiIon comparison for length of different brands). Measurements charger
![]() This charger has a very good CC/CV curve, the termination current is slightly high. ![]() My old 16340 is also charged fine. ![]() ![]() 250mA or 0.25A works just as good, just slower. ![]() During startup the charger has a periode with low charge current, my guess it that it is used to detect battery type. ![]() Increase in charge current is done with a slow ramp. NiMH batteries ![]() The charger does some pulsing while charging NiMH, it looks like the termination is a -DV termination. When terminated the charger will trickle charge, this is a good idea with NiMH (But prohibited with LiIon) ![]() Using 0.25A charge current is not a good idea for AA batteries, the charger has problems detecting when it is done. ![]() With AAA batteries at 0.25A charge current, the termination if detected earlier, but it is still not perfect. ![]() It takes 60 minutes to detect a full AA battery at 0.5A, not very good. ![]() Holding the button down with a NiMH battery in the charger will start a refresh function, where the battery is first discharged, then charged. ![]() The current selection is not used during discharge, only during charge. ![]() With a NiMH battery in the charger, it stays at the low current for about 2 minutes, before going to full charge current. ![]() During NiMH charge it will stop charging each other second, this is probably done to check the voltage. Conclusion This charger does a good CC/CV charging on LiIon and with 2 current settings it can handle a wide varity of small cell sizes. The NiMH charging has some problems with termination, making the termination a bit more sensitive and only allow charging at 0.5A would probably be a good idea. The charger is a very good LiIon charger and a acceptable NiMH charger. Notes Here is an explanation on how I did the above charge curves: How do I test a charger
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 21.08.2025 18:32
Сказал(а) спасибо: 1744
all wating xp4 review
![]() tnx for this
Продам фонари Convoy S3 с разной TIR оптикой |
| Поблагодарили: 2 раз(а) |
Magvay (11.09.2013), NazarSunrise (11.09.2013)
