Просмотров в теме 9764   Ответов в теме 30   Подписчиков на тему 3   Добавили в закладки 0
Старый 29.08.2013, 14:17 Автор темы   1
Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
По умолчанию Sunwayman C21C and Sunwayman T45C in stock and good price
Do not forget our coupon code: FLWALLBUYS
Sunwayman T45C CREE XM-L2 980LM 8-Mode Metallic Hollow-out White LED Flashlight-Black(2x18650)
Link: http://wallbuys.com/Product...
Price with coupon code: 73.11$+free shipping
Product Features
Brand: Sunwayman
Model: T45C
Material: Aluminium Alloy
Color: Black
Emitter Brand: CREE
Emitter Type: LED
Emitter BIN: XM-L2
Emitter Color: White
Total Emitters: 1
Brightness: 980LM(manufacturer rated)
Runtime: 130h(max.)
Beam Range: 278m(max.)
Modes: 8,Turbo(980LM,Automatically enter High mode after 5 mins continuous use to avoid overheat)-High(470LM,3.5h)-Mid(220LM,10h)-Low(20LM,130h)-Strobe-SOS-Police Strobe-Slow Strobe
Quick double-click at any mode-Strobe;Quick double-click at Strobe-SOS;Click and hold when the light is turned off-Police Strobe;Click and hold at Police Strobe-Slow Flash
Mode Memory: Yes
Switch Type: Side Switch?
Lens: Ultra-clear glass lens
Reflector: Metal Smooth/SMO Reflector
Circuitry: Constant Current Circuit
Voltage Input: 2.8-8.4V
Waterproof: IPX-8
Special Features: Exquisite hollow-out light head design, effective heat sink fin
Application: Outdoor/Lighting/Hunting/Riding/Camping
Battery-Powered: 2x18650(not included)
Dimensions: 136x41mm
Weight: 220.5g(excluded battery)
Packing List:
1 x Flashlight
1 x Lanyard
1 x O-ring
Sunwayman C21C CREE XM-L2 + XPE-P2 830LM 6-Mode LED Flashlight with Dual Light Sources-Black(1x18650)
Price with coupon code: 64.30$+free shipping
Product Features
Brand: Sunwayman
Model: C21C
Color: Black
Emitter Brand: CREE
Emitter Type: LED
Emitter BIN: XM-L2 + XP-E P2
Emitter Color: White+Red
Total Emitters: 2
Brightness: 830LM(manufacturer rated)
Runtime: 31h(max.)
Beam Range: 188m(max.)
Modes: White Light:Trubo(830LM,Automatically enter High mode after 5 mins continuous use to avoid overheat)-High(510LM,1.9h)-Mid(130LM,9.5h)-Low(42LM,31h)-Strobe-SOS
Red Light:High(98LM,3h)-Mid(63LM,9h)-Low(14LM,45h)-Strobe-SOS
Mode Memory: -
Switch Type: Top Press Button Switch
Lens: Ultra-clear glass lens + resin lens
Reflector: High quality metal streamlined reflector
Waterproof: IPX-8
Special Features: Equipped with newly-designed low-voltage indicator lamp;Independent dual light source
Battery-Powered: 1x18650(not included)
Dimensions: 107x27mm
Weight: 78g(excluded battery)
Packing List:
1 x Flashlight
1 x Lanyard
1 x O-ring
[Исправлено: cherryzhou, 30.08.2013 в 11:58] Причина: wrong type
cherryzhou вне форума   Ответить с цитированием Вверх
Старый 29.08.2013, 14:52   2
asket32420
Шурик с шуриком
Аватар для asket32420
Сказал(а) спасибо: 2009
По умолчанию Re: Sunwayman C21C and Sunwayman T45C in stock and good price
Посмотреть сообщение Сообщение от cherryzhou :
правильно понимаю, что с 2х123а попрет
Старый 29.08.2013, 15:00   3
Alex TG
Аватар для Alex TG
Последняя активность: 06.01.2026 22:26
Сказал(а) спасибо: 687
попрет, куда он денется
Uses one single 18650 battery (2*CR123A/16340 batteries)
Alex TG вне форума   Ответить с цитированием Вверх
asket32420 (29.08.2013)
Старый 09.09.2013, 01:26   4
Анатолий Францевич
Аватар для Анатолий Францевич
Последняя активность: 22.10.2018 23:00
Сказал(а) спасибо: 12
Какие вообще будут мысли о данном изделии?
Анатолий Францевич вне форума   Ответить с цитированием Вверх
Старый 09.09.2013, 04:53   5
Посмотреть сообщение Сообщение от Анатолий Францевич :
если ВООПЩЕ - покупай, расскажешь
[Исправлено: blindnick, 09.09.2013 в 05:01]
Старый 09.09.2013, 08:17   6
Анатолий Францевич
Хороший совет.
Тогда вопрос перефразирую. По какой причине вы бы купили Sunwayman T45C или не купили бы? Был у меня Феникс ТК35, если сравнить его с ним (хотябы по описанию, понимаю что владельцев нет) то какие сильные и слабые стороны?
Старый 09.09.2013, 08:36   7
весьма вероятный вариант - не рассматривать этот фонарик как кандидата на покупку с точки зрения технических параметров, ибо средненькие.
нравится? покупай.
не нравится - соответственно...
а вот с21с с красным диодом - очень интересный фонарик. как раз мелкоразмерный ближнего боя с дополнительной, практически уникальной, функцией
[Исправлено: blindnick, 09.09.2013 в 08:40]
Старый 09.09.2013, 09:44   8
Анатолий Францевич
Спасибо.
Т.е. даже в ровень с ТК35 ставить нельзя получается? Да вобще пока с такими размерами от 2-х 18650 ничего стоящего не нашел. Надо было феню не продавать, выклянчили. Вроде с какчеством у санвеев более менее
[Исправлено: Анатолий Францевич, 09.09.2013 в 10:26]
Старый 09.09.2013, 10:29   9
по какому параметру?
Старый 09.09.2013, 11:11   10
Анатолий Францевич
По всем. Продолжительность работы на максимальном режиме и средних, качество электроники и качество в целом, какие есть аксессуары, удобство пользования, надежность. Всё равно у ярых фонарёвщиков есть какие-то мысли, даже не имея на руках эти фонари смогут с большой долей правды обрисовать картину в целом
А вообще я навичёк, мне вопросы задавать не нужно опыта использования фонарей мало. Пару-тройку фирменных, и кучку безымянных. По этому и спрашиваю, стоит ли вообще обращать внимание на эти поделки.
Старый 09.09.2013, 11:22   11
никакой принципиальной разницы нет. если что-то интересует конкретно, то читай описания
Старый 09.09.2013, 11:28   12
Сказал(а) спасибо: 585
и кучку безымянных.
Это вот они -
эти поделки.
А в данной теме говорится про И-З-Д-Е-Л-И-Я!
Старый 09.09.2013, 13:44   13
Анатолий Францевич
Ну если купить фонарь от бренда, а он сломается, для меня он автоматически перейдёт в "поделки" Но тем не менее и поделками можно пользоваться.
Ну и не нашел я обзоров с восхищениями от удивительного долгоиграющего света и превосходного качества санвеев. Общее впечатление что нечно среднее, ничего плохого и ничего выдающегося.
Старый 09.09.2013, 13:53   14
какое точное описание феникса
одна категория цены и качества. хочется чего-то принципиально нового? ищи кастомы
если всё таки есть необходимость светить - конвои. если просто денюжки жгут ляжку, то что-ибудь титановое понтовобесполезное
[Исправлено: blindnick, 09.09.2013 в 13:55]
Старый 09.09.2013, 14:26   15
Анатолий Францевич
Нужен на 2-x 18650 расположенных параллельно, чтобы рабочие режимы 120-150 и 300-350 были по максимуму долгоиграющими и всё это на теплом. В турбо не принципиально какая яркость
Старый 09.09.2013, 14:42   16
В турбо
Анатолий Францевич, объясни мне, неучу, что такого в этом "турбо"? я понимаю, когда в ДВС для увеличения мощности включают нагнетатель (в просто речии турбину), или подают вместо воздуха закись азота - вот ЭТО турбо! а включать фонарик на 50...80% потенциала - это такой средненький максимум. к примеру, XM-L2 Т6 на токе 3А даёт 950 люмен света с диода - и это не предел, как выяснилось
если быть до конца с собой откровенным, то не "НУЖЕН", а "ХОЧЕТСЯ" - ибо таких фонариков всего три штуки во всём мире и стыдно при столь острой необходимости не знать их характеристики. в том числе и цены
ты хоть один фонарик нашёл по своим критериям? до сих пор только спекуляции одни "я новичок, дайте мне!"
ник настоящий? или припасён специально для психических атак? тролить надо тоньше, коллега
[Исправлено: blindnick, 09.09.2013 в 14:49]
Старый 09.09.2013, 16:47   17
Анатолий Францевич
Умничаете всё... Кому что хотите доказать? Что я в фонарях ничего не понимаю? Так я вам писал в другой ветке, что я пользователь, собирать/разбирать, менять светодиоды и драйвера не собираюсь.
Теперь вернёмся к "турбо". Как конечный пользователь, я иногда все таки читаю инструкции и вы меня все к этому призываете так вот, это слово не с головы, производитель часто технически возможный максимальный режим фонаря, его так называет и если честно мне плевать сколько это в процентах от его возможностей, будь то 50, 80 или даже 100. Опять пишу ерунду? Для меня он будет "турбо", зачем мне придумывать другое слово? Чтобы угодить Вам?
Пишу нужен, потому как нужен! Мне и это слово заменить? Хорошо, я нуждаюсь в фонаре такого класса, только необходимости как вы написали ОСТРОЙ нет, это ваши очередные выдумки.
И мне ни капельки не стыдно, что я не знаю этих три фонаря, а знаете почему? Потому как (специально для вас очередной раз) я конечный пользователь, и не слежу за новинками в мире фонарей. Что тут может быть не понятного, не понимаю Для этого и спрашиваю у знатоков, на форуме про фонари в большей степени (было бы странно если бы я про коней тут спросил).
Почему вы все время считаете что все мои вопросы адресованы именно вам? Если бы это было так, я бы обратился именно к вам (но не обращаюсь так как помощи и советов вы мне дать не можете)
Если все таки вы знаете то, чего не знаю я, почему бы не поделиться этим? Иль мала букашка, и времени потраченного не стоит?
Если нет, ваш ответ был очень прост (тем более вы себя преподносите как супер знатока, все для вас должно быть просто как 2Х2), а именно:
На сегодня таких фонарей мало, это А,В,С. А - хорош этим...., В - хорош....вот этим, С - в нем есть, того чего нет в А,В... Но так вы не напишите, так как убеждены, что я должен! нет ОБЯЗАН! Это знать. Только с чего вдруг? Мне книжку по полупроводникам тоже изучить, прежде чем писать тут на форуме? По линейным и не линейным цепям учебник? Фильтрам?
А можно было еще проще, перечислить явных лидеров в таком формате, и ваше любимое "читай инструкцию" изучай, сравнивай, нравится купи, не нравится не купи. За это уже можно будет сказать слова благодарности. только зачем? Да? Лучше же показать своё мнимое превосходство.
Конечно!
1. Всегда с собой Fenix DP32UE
2. Поисковый TN31
3. Подствольник пока скорее мёртв, чем жив
4. Налобник два претендента. Визард и Зебра
5. На двух параллельных 18650 нету (продал), ищу.
Только давайте на Вы, а то вы мне все ТЫ да ТЫ. Мы с вами фонарями на брудершафт не светили. Не уважение в каждом посте.
Нет конечно, фальшивый. Достался по наследству. понятия не имею что это значит, по крайней мере получше звучит чем blindnick
[Исправлено: Анатолий Францевич, 09.09.2013 в 17:56]
Старый 09.09.2013, 16:48   18
Это М3С4, ТК 35 и сабж, да?
Старый 09.09.2013, 16:53   19
ещё http://www.lupine.de/produc...
Старый 09.09.2013, 16:54   20
Linx
Аватар для Linx
Последняя активность: Вчера 21:44
Сказал(а) спасибо: 6564
М3С4
Я вот тоже как-то не сразу его вспомнил...
В этой жизни нам это точно не грозит
[Исправлено: Linx, 09.09.2013 в 16:55]
Время генерации страницы 0.16202 секунды с 15 запросами
