Просмотров в теме 9274   Ответов в теме 21   Подписчиков на тему 6   Добавили в закладки 0
Старый 26.08.2013, 12:46 Автор темы   1
Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
По умолчанию The Smallest and Brightest LED Flashlight in the World(use 18650 Battery)
Esit, now this flashlight is in stock!!
Mini S10 CREE XP-G2 R5-1A 450LM 5-Mode Cool White LED Flashlight-Gray(1x18650)
Link: http://wallbuys.com/Product...
Price: $12.87+free shipping
The designer of Jacob A60 finish his newest flashlight . here is the information and some pictures about it, wallbuys will sell it soon
Model :S10
LED Type: XP-G2 R5-1A
Color: Gray
Finish: Anode oxidation
Case Material: 6063-T5 Aluminum
Lens: Super white toughened glass edge grinding lenses
Reflector: Aluminum Textured
Max output: 5.5W
Mode Number: 5
Mode: High (1520mAh)-Middle (450mAh)-Low (75mAh)- Strobe-SOS
Brightness: 450LM
Total Emitter: 1
Circuit: 7135 * 4 constant current output
Switch: Tail button switch
Dimensions: 22.7mm (HD)*118mm(L)*22.7(TD)
Power Supply:1*18650 Battery(not include)
Runtime:2 hours
Weight: 50g
Here is a review for this flashlight:
The package just arrived. I'm impressed by the quality of this light for the money! Exactly as shown in the pictures.
Here's my initial pros and cons after studying the light and disassembly/reassembly. I added phaserburn's diffuser film to the inside of the lens before reassembly.
Pros:
Small outer diameter - yet all my 18650 cells slide in.
Square threads - quality fit and finish between body parts
Flawless anodizing & all parts match color.
Well sealed everywhere for great water resistance
Loosening tailcap will not loosen the switch - by design
Centered, clean emitter
Clean aluminum reflector
Throws well despite small reflector
Somewhat stiff reverse clicky switch (can't activate by accident)
Quite bright - no strange tint just cool white
Only 53 grams weight without a cell
Head not potted - easy access to upgrade emitter in the future
Current travels through the threads - so it isn't picky if the tailcap is loose
Sturdy spring at (+) terminal prevents accidental mode switching in rough environment
Flat-top cells work fine.
Cons:
Glass lens is hazy - cleaning both sides didn't help (I put diffuser film on it for wider beam anyway)
Too short to put the tailcap on the whole way using the very long protected Panasonic 3400 mA*h batteries, but it functions anyway because of non-anodized threads.
Switch boot is a little tall - wobbles during tail-standing, whether on or off.
No cutout for the lanyard or split ring to go when tailstanding.
Always comes on high (no mode memory)
Uses PWM for medium and low - but relatively high Hz
No Anti-roll features (other than included lanyard)
No Lock-out because tailcap is not anodized
No mechanical polarity protection
Limited power options (Not rated for voltage of two 123's)
Curiosities:
Center section seems reversible
Knurled region is not on tailcap
No markings anywhere on the body
Below is a picture of it sitting next to the light I've been using on my headband. About 25 grams lighter, noticeably smaller in diameter, and probably more waterproof than what I've experienced with the ST Cycler.
I used the light this morning during a 1 hour 10 minute run using an unprotected Panasonic 3400 mA*h cell. At first I tried medium. Because I put diffuser film on it for greater spill, it wasn't quite as bright as what I'm used to with the Jetbeam on medium. After the first 10 minutes I switched to high and the light performed flawlessly the rest of the way, never getting too hot. The PWM was never noticeable on any setting. The cool white color was only an issue when I hit some fog, otherwise it was pleasant.
The torch was definitely less weight on my head than I've been used to with the ST. It fit within the loops of the Nitecore HB02 headband better and flopped around side to side much less.
If I have one wish it would be for this light to use an XM-L for more spill so I wouldn't have to use diffuser film.
I highly recommend the light for the $12 paid. It's probably the best budget light I've ever bought.
[Исправлено: cherryzhou, 23.09.2013 в 07:11] Причина: picture
cherryzhou вне форума   Ответить с цитированием Вверх
vorsmann (30.08.2013)
Старый 26.08.2013, 12:54   2
Последняя активность: Сегодня 13:30
Сказал(а) спасибо: 17650
Поблагодарили: 39854 раз(а) в 14738 сообщениях
По умолчанию Re: The Smallest and Brightest LED Flashlight in the World(use 18650 Battery)
Не хватает клипсы.
И мигалки убрать бы...
Старый 26.08.2013, 13:21 Автор темы   3
cherryzhou
hello sir, thanks for your comment, it has no clip, but it has strap
Старый 26.08.2013, 14:58   4
Koh
Аватар для Koh
Последняя активность: 09.04.2025 16:51
Сказал(а) спасибо: 151
Поблагодарили: 121 раз(а) в 82 сообщениях
Да, мигалки убрать однозначно, ровно как и лак с ногтей того мужика.
Koh вне форума   Ответить с цитированием Вверх
Старый 26.08.2013, 15:55   5
viperxp
Аватар для viperxp
Последняя активность: 26.07.2025 11:59
Сказал(а) спасибо: 144
Koh, рука похоже женская.
Olight Разные ZebraLight SC5W
viperxp вне форума   Ответить с цитированием Вверх
Старый 26.08.2013, 16:25   6
Последняя активность: Сегодня 14:32
Сказал(а) спасибо: 6695
Поблагодарили: 36165 раз(а) в 16707 сообщениях
"The designer of Jacob A60 finish his newest flashlight"
тут уже нельзя сказать с уверенностью мужская иди женская.. дезигнеры они такие дезигнеры бывают...
но где цена?
Старый 26.08.2013, 17:02   7
VityaS
Последняя активность: 19.07.2022 21:35
Сказал(а) спасибо: 16
Поблагодарили: 55 раз(а) в 32 сообщениях
Smallest? Brightest?
What about it?
VityaS вне форума   Ответить с цитированием Вверх
Старый 26.08.2013, 17:21   8
ssr
Аватар для ssr
Сказал(а) спасибо: 80
Старый 27.08.2013, 01:47   9
Sasha :)
Перипатетик
Аватар для Sasha :)
Последняя активность: 04.01.2025 11:02
Сказал(а) спасибо: 122
Пилюля короткая, всего два витка. Можно было бы сделать больше, в корпусе резьба более глубокая.
Sasha :) вне форума   Ответить с цитированием Вверх
Старый 27.08.2013, 09:47   10
Mihalich
Аватар для Mihalich
Сказал(а) спасибо: 838
Price? Link?
Посмотреть сообщение Сообщение от cherryzhou :
Why, why?
They should be hidden!!!
Убивец СИДов
[Исправлено: Mihalich, 27.08.2013 в 09:49]
Mihalich вне форума   Ответить с цитированием Вверх
Старый 27.08.2013, 10:52 Автор темы   11
cherryzhou
thanks for all members, and now we are test this flashlight, after we finish it, we will add it in our shop soon, I think the price will be about 15$, just waiting for it
Mihalich (27.08.2013)
Старый 29.08.2013, 11:55 Автор темы   12
cherryzhou
Посмотреть сообщение Сообщение от Mihalich :
Price? Link?
Why, why?
yes sir,the Price : $12.87 +free shipping
Link : http://wallbuys.com/Product...
Mihalich (02.09.2013)
Старый 29.08.2013, 12:47   13
все думал, что он мне напоминает... по конструкции.
TrustFire TR-801 - второе рождение. теперь с сразу правильным драйвером
и практически в тех же габаритах.
Старый 29.08.2013, 23:34   14
Al
Аватар для Al
Сказал(а) спасибо: 1730
Конечно $12.87 + free shiping это аргумент, но сейчас фонари на одной 123 выдают за 500lm.
Старый 30.08.2013, 22:40   15
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
Сказал(а) спасибо: 10202
Симпатичный фонарик. Еще и разборный вообще класс.
In Fino verytas
Старый 30.08.2013, 22:42   16
vorsmann
Ветеринар Фонаревки
Аватар для vorsmann
:sun_smile: Re: The Smallest and Brightest LED Flashlight in the World(use 18650 Battery)
Посмотреть сообщение Сообщение от VityaS :
What about it?
Не а диод то другой.
Старый 02.09.2013, 13:58 Автор темы   17
cherryzhou
the different between http://www.cnqualitygoods.c... and our Mini S10 is, our flashlight is tail switch flashlight , it is easy to control
Старый 02.09.2013, 13:59 Автор темы   18
cherryzhou
Старый 27.11.2013, 11:42   19
Внезапно добежал фонарик с распродажи.
Драйвер нелепый, старт с максимума и далее перебор со стробами.
А в остальном очень неплохо за свои пять долларов, вечерком разберу и гляну, что с внутренностями.
Старый 27.11.2013, 17:23   20
он же звездатый, типа вот
Время генерации страницы 0.14320 секунды с 15 запросами
