2390
http://www.hkequipment.net/...
![]() ![]() ![]() ANSI Illumination levels: Turbo High Mid Low Red On SOS Impact Resistance: 1.5m, Waterproof: IPX8 LED: CREE XP-G2 R5 LED (main light) CREE Φ5.00mm High output Red light Crust Materials: Anodized aircraft 6N01 aluminum alloy, type III hard-anodized anti-abrasive finish Working Voltage: 0.9~4.2V Switch: Side clicky switch Size: Φ23.0mm(Head dia)x Φ21.5mm(Body dia)xΦ21.5mm(Tail dia)x97mm(length) Net Weight : 53g(Excluded batteries) Additional Functions: Battery type recognition, Automatic shift down, over-discharge protection Features: 1.Battery type recognition, different battery provides different output 2.Automatically shift down: When use lithium batteries, H1 could switch to high from turbo automatically. and voltage is below 3.0, it switch to Low mode, and voltage is below 2.75V, H1 turn off automatically. 3. Dual light sources, main light is for lighting and secondary light is for Signal use. 4.Click the switch to change between lighting modes, Double click the switch to access and change between the signal modes. In either signal mode, pressing the switch once changes to Low mode. 5. Reverse-polarity protection to prevent damage from incorrect battery insertion Package includes (original blister packaging): XTAR Headlight Stainless Steel Clip Silicone strap Lanyard O-ring Pocket Clip Operation Manual Warranty Card
hkequipment Web : http://www.hkequipment.net MSN : info@hkequipment.net Skype / ******* : hkequipment Paypal : pay@hkequipment.net |
