10534
Регистрация: 10.05.2013 Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
Activity Background :
Today is Lumintop Ltd's 3 years Anniversary Celebration, then they support us to provide this Group buy plan .The quality of Lumintop flashlights is good,and during this this Anniversary, Lumintop Ltd wish more people can get their flashlights in best price and get a brighter life. ![]() Flashlights and group buy price: Lumintop SD10 GB Price:50$ Lumintop ED20 GB Price:49$ Lumintop TD16 GB Price:85$ Activity Rules: 1. There are 3 items you can choose, so there are 3 different GB plan will start. 2.If you want to buy anyone, reply the post like this " I want 1 pcs of Lumintop TD16 " or " I want 1 pcs of Lumintop SD10 and 1 pcs of Lumintop TD16 " 3.The quantity of any flashlight up to 50 pcs, then the GB plan start . Notice: The number is enough then the GB plan will start. Lumintop SD10 CREE XM-L2 T6 800 LM 4-Mode White LED Flashlight-Black(3xAA/1x32650) GB Price:50$ ![]() Link: http://wallbuys.com/Product... Product Features Brand: Lumintop Model: SD10 Material: Aluminum Alloy Color: Black Emitter Brand: CREE Emitter Type: XM-L2 Emitter BIN: T6 Emitter Color: White Color Temperature: - Total Emitters: 1 Brightness: 800LM(1x32650)500LM(3xAA) Runtime: 7.5-280h(1x32650)6-150h(3xAA) Beam Range: 260m(1x32650)209m(3xAA) Modes: 4,High>Mid>Low,Strobe OFF State:Press the switch for more than 0.5s to turn on the light,press for another 0.5s will turn the light off.On state:Single press,circle of High-Mid-Low,double click switch to enter into Strobe mode Mode Memory: Yes Switch Type: Front side switch Lens: Glass Reflector: Aluminum Smooth Reflector Circuitry: Constant current circuit Voltage Input: 0.9-4.5V Waterproof: IPX-8 Special Features: Battery reverse polarity function guards against improper battery installation Application: Outdoor/Lighting/Hunting/Camping/Riding Battery-Powered: 3xAA/1x32650(excluded) Dimensions: 120.3(L)x40(D)mm(excluded battery) weight: 123g(exclude battery) Packing List : 1 x Flashlight 1 x Strap 1 x O-Ring Lumintop ED20 CREE XM-L2 750 LM 2-Group 3-Mode White LED Flashlight-Black(1x18650) GB Price:49$ http://wallbuys.com/Product... ![]() Product Features Brand: Lumintop Model: ED20 Material: Aluminum Alloy Color: Black Emitter Brand: CREE Emitter Type: XM-L2 Emitter BIN: - Emitter Color: White Color Temperature: - Total Emitters: 1 Brightness: 750LM Runtime: 2-50h Beam Range: 200m Modes: 2-Group 3-Mode,High-Mid-Low,Strobe-Flash-Slow Flash Tighten the head. Press the tailcap switch ON/OFF to switch between 3 output modes: Low,Mid and High. Turn on the light after 3 seconds off. Loosen the head. Press the tailcap switch ON/OFF to switch between 3 blinking modes: Strobe, Flash and Slow Flash. Mode Memory: Yes Switch Type: Push-button tail cap switch Lens: Glass Reflector: Aluminum Textured/OP Reflector Circuitry: Constant current circuit Voltage Input: - Waterproof: IPX-8 Special Features: Battery reverse polarity function guards against improper battery installation Application: Outdoor/Lighting/Hunting/Camping/Riding Battery-Powered: 1x18650/2xCE123A(excluded) Dimensions: 120.5(L)x26(HD)x25.4(D) Weight: 84.5g(excluded battery) Packing List: 1 x Flashlight 1 x O-Ring 1 x Tailcap Rubber Boot 1 x Holster Lumintop TD16 CREE XM-L2 T6 1000 LM 2-Group 3-Mode White LED Flashlight-Balck(1x18650/2xCR123A) GB Price:85$ http://wallbuys.com/Product... ![]() Product Features Brand: Lumintop Model: TD16 Material: Aluminum Alloy Color: Black Emitter Brand: CREE Emitter Type: XM-L2 T6 Emitter BIN: - Emitter Color: White Color Temperature: - Total Emitters: 1 Brightness: 1000LM Runtime: 1.5-40h Beam Range: 310m Modes: 2-Group 3-Mode,High-Mid-Low,Strobe-Flash-Slow Flash OFF state:Press tactical tailcap switch for momentary-on, click it for constant-on. ON state: Click front side switch to switch between 3 output modes: Low,Mid and High. At any general mode, press it for more than 0.5s to switch between 3 signal modes: Flash, Slow Flash and Strobe. Mode Memory: Yes Switch Type: Tactical tailcap switch & Front side switch Lens: Glass Reflector: Aluminum Smooth Reflector Circuitry: Constant current circuit Voltage Input: - Waterproof: IPX-8 Special Features: Battery reverse polarity function guards against improper battery installation Application: Outdoor/Lighting/Hunting/Camping/Riding Battery-Powered: 1x18650/2xCR123A(excluded) Dimensions: 153(L)x38.5(HD)x26(D)mm weight: 156g(excluded battery) Packing List 1 x Flashlight 1 x Holster 1 x O-Ring 1 x Strap 1 x Tailcap Rubber Boot If you want to buy anyone, reply the post |
Регистрация: 10.06.2010 Последняя активность: 04.11.2025 21:38
Записей в дневнике: 1 Сказал(а) спасибо: 59
but what about the quality of light, the last I bought L2A was terrible compared with the purchased half a year earlier.
Электроника - наука о контактах! |
