Просмотров в теме 2720   Ответов в теме 1   Подписчиков на тему 2   Добавили в закладки 0
Старый 06.08.2013, 23:17 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Sibeile IMR18650 3400mAh (Black)
Official specifications:
  • Nominal Capacity: 3400mAh(0.2C, 2.50V discharge)
  • Minimum Capacity: 3350mAh (0.2C, 2.50V discharge)
  • Charging Voltage: 4.2±0.05V
  • Nominal Voltage: 3.6V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1700mAh, Rapid charge: 3400mAh
  • Charging Time: Standard charge: 3 hours, Rapid charge: 2.5 hours
  • Discharge Cut-off Voltage: 2.50V
  • Cell Weight: 48g max.
  • Cell Dimension: Height: 65.00mm max. Diameter: 18.25mm max.
  • Operating Temperature: Charge: 0 to 45 °C Discharge:-20 to 60°C
This battery performs like the Panasonic 3400mAh cell with added protection.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
After shipping the samples to me, some print was added to the box.
The discharge curves has good tracking, but the protection in this battery has a rather low current limit, it prevented doing a 3A discharge test.
Conclusion
With the exception of the low current limit this cell has good performance.
Notes and links
According to Sibeile the IMR text will be removed from the next batch of cell.
The batteries was supplied by Sibeile for review.
blindnick (06.08.2013), Dnv (07.08.2013), Gary (07.08.2013), NazarSunrise (06.08.2013)
Старый 06.08.2013, 23:22   2
NazarSunrise
Turn Day into Night
Аватар для NazarSunrise
Сказал(а) спасибо: 1744
По умолчанию Re: Test/Review of Sibeile IMR18650 3400mAh (Black)
NazarSunrise вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.09293 секунды с 15 запросами
