3092
Fenix PD35 XM-L2 Stock arrived. Coupon PD35off
http://www.hkequipment.net/... Features of Fenix PD35: • Cree XM-L2 (U2) LED with a lifespan of 50,000 hours • Uses one 18650 rechargeable battery (Li-ion) or two 3V CR123A batteries (Lithium) • Output mode / Runtime: Turbo: 850 lumens / 1h 15min High: 450 lumens / 2h 30min Mid: 170 lumens / 7h 45min Low: 45 lumens / 29h Eco: 10 lumens / 140h Strobe: 850 lumens • Dimensions and Weight: Length: 5.1" / 130mm Diameter: 1.0" / 25.4mm Head Diameter: 1.0" / 25.4mm Weight: 3.1oz / 87gm • Digitally regulated output - maintains constant brightness • Reverse polarity protection, to protect from improper battery installation • Over heat protection to avoid high-temperature of the surface • Anti-roll, slip-resistant body design • Tactical tail switch with momentary-on function • Side switch in the head • Made of durable aircraft-grade aluminum • Premium Type III hard-anodized anti-abrasive finish • Toughened ultra-clear glass lens with anti-reflective coating
hkequipment Web : http://www.hkequipment.net MSN : info@hkequipment.net Skype / ******* : hkequipment Paypal : pay@hkequipment.net [Исправлено: hkequipment, 21.07.2013 в 21:30] |
