6203
Lumintop SD10 Cree XM-L2 T6 Flashlight 800lm - Coupon SD10off
http://www.hkequipment.net/... Description SD10 is one of the world’s smallest, lightest and brightest 32650 searchlight. It is compatible with a wide range of batteries through intelligent control, and thus it has different outputs based on different battery types. It ensures not only enough brightness but also product stability and long runtime. With premium CREE XM-L2 T6 LED, its output reaches up to 800 lumens, distance 260m. Construction: - Coated tempered window resists impact - Aerospace aluminum uni-body design combined with a stainless steel retaining ring offers superior impact resistance. Mil-Spec hard-anodized. O-ring Sealed. - Front side switch, Slip-resistant body design. - Superb heat release system provides excellent heat transport capacity. - IPX-8 Water Resistant 2m, impact resistant 1.5m - Lengthened lanyard hole with tail-standing design. Operation: A. OFF State: Press and hold the front side switch for more than 0.5 seconds to turn on the light, while another press for 0.5 seconds will turn the light off. B. ON State: Click the front side switch to switch between 3 output modes: High, Medium and Low. Double click the switch to enter into Strobe mode, after another click, the light will go back to original brightness. It memorizes last brightness level when the light is turned off, while Strobe will not be memorized. Compatible with 3x AA, 1x 32650 or 1x D size High 800lm (7.5h), Mid 100lm (26h), Low 10lm (280h) by 1x 32650 High 500lm (6h), Mid 100lm (15h), Low 10lm (150h) by 3x AA High 200lm (7.2h), Mid 30lm (80h), Low 2lm (60days) by 1x D size with Strobe Mode Size 120.3mm x 40mm, Weight 115g
hkequipment Web : http://www.hkequipment.net MSN : info@hkequipment.net Skype / ******* : hkequipment Paypal : pay@hkequipment.net [Исправлено: hkequipment, 12.07.2013 в 21:59] |
| Поблагодарили: 5 раз(а) |
asket32420 (13.07.2013), crus (13.07.2013), NazarSunrise (13.07.2013), WallE (13.07.2013), Псевдоним (12.07.2013)
Регистрация: 30.06.2011 Последняя активность: 16.09.2025 17:24
Сказал(а) спасибо: 978
Поблагодарили: 217 раз(а) в 144 сообщениях
59 баксов + дисконт. Дайте два, завтра пойду карточку для покупок пополню
Юридическая помощь в оффлайн или дистанционно хороший-адвокат.рф |
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 21.08.2025 18:32
Сказал(а) спасибо: 1744
Хотя рантаймы, смотрю, весьма неплохи...
Продам фонари Convoy S3 с разной TIR оптикой |
Регистрация: 04.04.2011 Последняя активность: 10.12.2025 04:42
Сказал(а) спасибо: 503
Шурик с шуриком
большой литий тоже интересно
вполне себе попал в концепт дежурного фонаря домой |
Псевдоним (13.07.2013)
Turn Day into Night
