Просмотров в теме 3423   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 10.07.2013, 14:26 Автор темы   1
Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
По умолчанию Solarforce M9 and Olight H15 Wave are available now
Now Solarforce M9 and Olight H15 Wave are available now,and do not forget our coupon code : QSFKBUSSAQRT
Solarforce M9 CREE XM-L2 U2 1000 LM 550 Meters Throw 4-Mode High Power LED Flashlight-Black(1/2x18650)
Price with coupon code : 74.06$+free shipping
Link : http://wallbuys.com/Product...
M9 uses the revolutionarily powerful and long-lasting white CREE XM-L2 LED, which is significantly more superior to the old generations in terms of power output and efficiency. Over 90% of the white light emitted from the LED is nicely focused by a precisely-engineered aluminum-alloy reflector with its mirror-like reflective surface, producing a powerful beam which is suitable for illumination of long distance. The micro integrated circuit installed stably regulates the output of the flashlight throughout the runtime of each set of batteries.
Besides the tail-cap switch, M9 has a unique separate output-controlling button for switching the output levels between high, medium, low and moon mode. In order to facilitate its users, both the strobing and SOS modes are hidden with this button. The output memory function (please see the operation instructions below for more details) of the tail-cap switch makes the M9 a very easy-to-use as well as convenient tool.
The body of M9 is made of T6063 T6 aircraft grade aluminum alloy with precise CNC machines, in Mil-spec type III hard-anodized finish. The compact and durable design makes the M9 an extremely robust and durable tool under extreme and hostile environments. The elegant design, powerful output and pragmatic functions of the M9 make it the best option to all professional users.
Lumens rating and runtime (using 1 or 2 pcs of Solarforce S18650P (V3) batteries):
High: 620 lumens / 150 mins or 1020 lumens / 95 mins.
Medium: 215 lumens / 7 hrs or 440 lumens / 3 hrs and 50 mins.
Low: 28 lumens / 50 hrs or 125 lumens / 13 hrs.
Moon-mode: 1 lumen / 1000 hrs or 5 lumens / 300 hrs.
Olight H15 Wave CREE XM-L 150 LM 2-Mode Gesture Control LED Headlamp-Black(4xAAA)
price with coupon code : 36.40$+free shipping
The H15 Wave is Olight's first headlamp and it packs in the same amazing construction and industry-leading functionality as the rest of its line of hand held devices. The Wave features dual output modes with the bright CREE XM-L LED as well as a Red LED and Red strobe. Capable of producing 150 lumens on high, this 4 x AAA headlamp is as powerful as it is versatile.
Gesture activation allows the user to turn the light on and off simply by waving a hand in front of the headlamp. This means that wet, muddy, or otherwise incapacitated hands will never be an issue again. A built-in diffuser lens can be flipped up and down with the push of a button so you can get the best beam qualities for your situation.
cherryzhou вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.08378 секунды с 15 запросами
