2479
Регистрация: 10.05.2013 Последняя активность: 11.06.2014 14:22
Поблагодарили: 30 раз(а) в 19 сообщениях
after use the coupon code , then the price is 71.1$,coupon code : WSSDDGAA
Blackshadow FIRE CREE XM-L U2 500 LM TWO Group Stainless Steel LED Flashlight (1x18650/2xCR123A) Link : http://wallbuys.com/Product... ![]() ![]() price with coupon code : 71.1$+free shipping Brand: BLACKSHADOW Model: FIRE Material: Stainless Steel Color: Silver Emitter Brand: CREE Emitter Type: XM-L Emitter BIN: U2 Emitter Color: White Total Emitters: 1 Brightness: 500LM Runtime: 2-8h Beam Range: 350m Modes: Two Groups Group I: Hi>Strobe (Tight tail part) Group II: Hi>Lo>SOS (Contrarotate 60 degree) Mode Memory: - Switch Type: Tail cap click switch Lens: Glass Lens Reflector: Aluminum Alloy Mill Reflector Circuitry: Constant Current Circuit Voltage Input: - Waterproof: IPX-8 Special Features: Thermal Design Application: Hiking/Cycling/Searching/Caving Battery-Powered: 1 x 18650 / 2 x CR123A (not included) Dimensions: 159mm(L)x36mm(HD)x23mm(TD) Weight: 350g(without battery) Packing List: 1 x Flashlight 1 x Strap 1 x O ring 1 x Warranty Card 1 x Manual |
