5475
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
UltraFire UF26650 5000mAh (Flame)
![]() Official specifications:
![]() These batteries are protected 26650 and the limit is rather low for the size. ![]() ![]() ![]() ![]() ![]() ![]() The two batteries tracks very fine. ![]() ![]() ![]() It looks like the protection on the B battery trips just before the 5A trace is finished. The reason the voltage increases, is due to a chain of events: First the protection disconnects the battery, because the voltage now is below the minimum voltage my load disconnects, without any load the protection in the battery reconnects, the voltage is now higher because it is unloaded, I measure the voltage and stops the discharge cycle (All this happens in less than 1 second). ![]() ![]() ![]() Conclusion These batteries has a good performance for cheap batteries, except for the "low" current limit I do not have anything to complain about. Notes and links The batteries was supplied by LightCastle for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
неплохой аккумулятор вроде - сопротивление, ёмкость, токоотдача
а то расцветка ОЧЕНЬ сильно напоминает огненную ткрмоусадку трастфаера, если перепутаешь - немного потеряешь
трол. |
Сказал(а) спасибо: 12
Сказал(а) спасибо: 1935
0,08 ома много. У кингконгов 0.05.
