6452
Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
http://www.sunwayman.com/ht...
Features ● CREE XM-L U3 LED, with a lifetime of up to 50,000 hours; ●Tail cap tactical forward clicky switch, slightly depress the side switch for different output modes: one turbo mode, three constant output modes, hidden strobe, slow strobe, police strobe and SOS functions(below is the output and runtime of using one single 18650). Turbo mode : 600 lumens Three constant output modes: 350 lumens (2.4hrs) – 75 lumens (12hrs) – 8 lumens (104hrs) ● Constant current circuit, constant output; ● Effective range of 300 meters; ● Uses one single 18650 or two CR123A/RCR123A/16340 batteries; ● Built-in charging module, can be applied to one 18650 battery, NOT 16340 or RCR123A batteries; ● Working voltage: 3~8.4V; ● High quality metal reflector maintains great throw distance and spread with an ideal beam pattern; ● Dimensions: 153.8mm (length) x 41.3mm (head diameter) x 30mm (tail diameter); ● Weight: 163g(battery excluded); ● Aerospace-grade aluminum alloy, solid and stable construction; ● Military specification Type III- hard anodized body; ● Waterproof, in accordance with IPX-8 standard; ● Ultra-clear tempered glass lens resists scratches and impacts; ● Tactical tail cap press button switch for momentary on; ● Accessories: charger, holster, O-ring, rubber cap, plug, lanyard. Operation Tactical tail cap press button switch: half depress the tail cap switch at any mode for turbo mode; release to return to the original status. Fully-depress the tail cap switch to lock the turbo mode. Under any mode, continuously half-depress the tail cap switch for more than three times, and fully depress at the last time for strobe mode. Switching of two dimming modes: when the light is turned on by fully depressing the tail cap switch at any mode, depress and hold the side switch twice (each for more than 2 seconds), the light will slightly flicker and when the flicker stops, the dimming mode is switched successfully. Dimming mode 1 (default): correctly install the batteries, depress the side switch once for turbo mode (after 5 minutes’ turbo mode, the light will go to high mode automatically to avoid over-heat). With the flashlight on, depress the side switch to change the mode, and one press for one mode. The output modes cycle through “Turbo/High- Mid- Low- Off”. Dimming mode 2: depress the side switch to turn on the light at turbo mode. Depress and hold the side switch for all output modes cycling through “Turbo/High- Mid- Low”, release to lock your desired mode. Depress the side switch again to turn the light off. At any mode, quick double click the side switch for strobe mode, double click it once more for SOS mode. At any mode, half depress the tail cap switch for turbo mode, fully depress it to lock this tactical output. When the light is at turbo mode, depress the side switch once for police strobe, and depress it again to return to turbo mode, and by double clicking the side switch, the light will enter slow strobe. Release the tail cap switch for the original output status before depressing it. Dimming mode 1 is the default setting. In the condition of the dimming mode 2, after taking out the batteries, it will return to dimming mode 1 automatically. T21CS has memory function, it always memorizes the output mode before switching it off in the condition of not power off (strobe modes are excluded). ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
[Исправлено: uV3, 07.03.2013 в 14:08] |
Регистрация: 06.12.2012 Последняя активность: 01.12.2025 17:15
Сказал(а) спасибо: 516
ну и зачем ставить бин u3 на 600лм ?!
fnksb, ну можно было бы сделать т6 с3 например
Sunwayman ставит нейтральные диоды на ограниченные серии фонарей.
Видимо, маркетологи приносят оттенок в жертву яркости и энергоэффективности. |
Записей в дневнике: 4 Сказал(а) спасибо: 17770
Поблагодарили: 40146 раз(а) в 14867 сообщениях
Можно было бы и U2 3C поискать, который, похоже, сумел найти Nitecore, если он не врет
![]() А Санвей вообще старается ставить самые последние и яркие бины, и правильно делает. То, что при этом не смотрит на температуру и порой попадаются совсем синюшные - так это и на U2 у них было, и даже на R5
Разницу в 20% яркости между U3 и T5 глаз едва заметит, зато на T5 найти нейтральный оттенок легко. [Исправлено: uV3, 07.03.2013 в 16:43] |
Производитель захотел поставить холодный диод - это плохо. Но то, что поставил топовый из холодных бинов - это хорошо. А то, что почти наверняка не занимался более тщательным отборов оттенков этого диода и ставил что придется - это плохо. Захотели бы поставить нейтральный - ставили бы нейтральные T6 или даже U2, т.е. опять же топовые на данный момент (ну, не считая XM-L2, конечно). |
fnksb, тут речь идет о 600лм было бы 800-900 прошел бы мимо)
подать чуть-чуть больший ток и те же самые 600лм приятного нейтрально-теплого света. |
Светят.Зашёл на огонёк :)
Регистрация: 20.01.2013 Последняя активность: 05.05.2022 05:01
Сказал(а) спасибо: 1469
Ааа... за 46 баксов?
Хотя, и за 46 чот не хочется
