Просмотров в теме 3295   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 13.01.2013, 13:27 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Efest 18650 3100mAh (Black)
Official specifications:
  • Efest 18650 3100mAh 3.7V Protected (Nipple)
  • Nominal Capacity: 3100mAh (0.2C, 2.50V discharge)
  • Minimum Capacity: 2950mAh(0.2C, 2.50V discharge)
  • Charging Voltage: 4.2 ±0.05 V
  • Nominal Voltage:3.6V
  • Charging Method CC-CV (constant voltage with limited current)
This battery uses a unusual construction with the protection mounted at the + pole. The maximum current from this battery is not very high, probably due to the unusual protection placement.
Protection trip current is to low to show in the chart.
Conclusion
This battery uses a very good cell and is one of the shortest 3100mAh protected batteries, but due to the low current limit it will not work in all lights (The problem is XM-L lights).
Notes and links
Rocklight (13.01.2013)
Время генерации страницы 0.08261 секунды с 15 запросами
