Просмотров в теме 32853   Ответов в теме 52   Подписчиков на тему 8   Добавили в закладки 0
Старый 08.12.2012, 22:36 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4331
Поблагодарили: 10698 раз(а) в 2546 сообщениях
Wink2 Новинка! Olight SR95S UT (SBT-70, 1350 Lumen)
OLIGHT SR95S UT ULTIMATE
Description
The Olight SR95S Intimidator Ultra Thrower (SR95S UT for short) is a special
edition of the SR95UT. The SR95S UT inherits the sturdy SR95 frame with an
upgraded Luminus SBT-70 LED, which adopts un-encapsulated die with a low
profile protective window to get perfect light intensity by optimizing focus on the
reflector.The new SBT-70 LED is combined with Olight’s special designed
reflector and the SR95’s well-established platform. The SR95S UT achieves
staggering 1000 meters of ultra-throw ability, making it an industry leader in
performance.
Specifications
Key Features
1. Uses world-class super bright revolutionary round LED --- Luminus SBT-70;
2. Max.Beam Intensity:250,000cd , Max.Beam Distance:1000m;
3. The lighting source adopts an un-encapsulated die to get perfect light intensity by optimizing focus on the reflector;
4. The 7800mAh 7.4V 18650 rechargeable lithium battery can also be used in SR90/91/92/95 with a perfect compatibility;
5. Hollow out structure in the head reduces weight by 25% compared to traditional sealed packet design;
6. The hollow out structures achieve twice the cooling surface area than that of solid design.;
7. Lens: tough ultra-clear tempered glass, with anti-reflective coating;
8. The large square surface texture in the body increases grip for a steady to hold;
9. A large, 18mm diameter button makes the light easy to operate;
10. Olight patented lock out function
Manual
SR95SUT?????-23534871672.pdf
http://www.olightworld.com/...
C055792 (13.12.2012), serOrel (31.12.2012)
Старый 08.12.2012, 22:54   2
Goldin
Последняя активность: 19.03.2023 12:51
Сказал(а) спасибо: 91
Поблагодарили: 39 раз(а) в 34 сообщениях
По умолчанию Re: Новинка! Olight SR95S UT
Это наверно как -типо случайно забыли айфон в баре )))
Goldin вне форума   Ответить с цитированием Вверх
Старый 08.12.2012, 23:06 Автор темы   3
Admin
Администратор
Аватар для Admin
Ждем более верной информации по спецификации...
AWL заметил ошибку в описании
Старый 08.12.2012, 23:18 Автор темы   4
Admin
Администратор
Аватар для Admin
В первом посте оставил то, что соответствует действительности.
Старый 11.12.2012, 09:09 Автор темы   5
Admin
Администратор
Аватар для Admin
По умолчанию Re: Новинка! Olight SR95S UT (SBT-70, 1350 Lumen)
Информация в первом сообщении обновлена.
Старый 11.12.2012, 20:50   6
6uka
Аватар для 6uka
Последняя активность: 08.11.2022 08:52
Ждемс
6uka вне форума   Ответить с цитированием Вверх
Старый 12.12.2012, 19:57   7
awl
Аватар для awl
Сказал(а) спасибо: 208
Догнали всё-таки до километра в финальной версии
[Исправлено: awl, 12.12.2012 в 20:02]
Старый 12.12.2012, 22:16   8
Freind
Последняя активность: 23.02.2024 17:30
Сказал(а) спасибо: 52
Поблагодарили: 50 раз(а) в 43 сообщениях
Посмотреть сообщение Сообщение от awl :
А толку? На таком расстоянии даже днём в солнечную погоду мало что разглядишь. Да и всё что в карман не влезает в наше время уже неинтересно.
Freind вне форума   Ответить с цитированием Вверх
Старый 13.12.2012, 00:39   9
motogans
Моторезиновый
Аватар для motogans
Последняя активность: 17.01.2026 21:23
Сказал(а) спасибо: 335
Freind, ну кому как.У каждого свои цели использования фонаря и свое зрение.Может 'просто посветить'-размер и великоват,а кому он действительно нужен для определенных целей,тот об интересе не задумывается.
Старый 13.12.2012, 00:59   10
C055792
Аватар для C055792
Последняя активность: 12.04.2020 20:54
Сказал(а) спасибо: 6
Поблагодарили: 37 раз(а) в 18 сообщениях
Месяц назад получил долгожданный Olight SR95 UT... теперь не знаю что делать продавать его и заказывать Olight SR95S UT. Хотел самый дальнобойный ....поспешил! Думал опять года 1.5 - 2 обновлений не будет. А они и пол года не прошло как новый выпустили...хотя бы сообщили что ожидается новая версия.
C055792 вне форума   Ответить с цитированием Вверх
Старый 13.12.2012, 21:22   11
PASHA
вечный n00b
Аватар для PASHA
Сказал(а) спасибо: 5257
интересен ценник
Старый 13.12.2012, 23:11   12
C055792
Аватар для C055792
450$
PASHA (16.12.2012)
Старый 13.12.2012, 23:39   13
C055792
Аватар для C055792
Старый 13.12.2012, 23:42   14
motogans
Моторезиновый
Аватар для motogans
ААААААААААА!!!!!Йа ща сума сойду!!!Огонь,хочу!
Старый 14.12.2012, 00:24   15
Светлячок
Авторизованный Хемуль
Аватар для Светлячок
Сказал(а) спасибо: 985
до облаков, наверное, можно добить...
Старый 14.12.2012, 00:28   16
Посмотреть сообщение Сообщение от Светлячок :
обрати внимание на первую пару фоток и на последнюю фотку - столбы света кончаются сами по себе, ничего в конце не освещая...
чтобы увидеть пятно на облаках, придётся отойти от фонарика подальше, метров на 10...50 - хз.
и оставить без присмотра на дороге штуку баксов
Старый 14.12.2012, 00:36   17
Светлячок
интересно, а будет ли видно пятно на облаках за горизонтом?
http://ru.wikipedia.org/wik...
с высоты человеческого роста горизонт находится на расстоянии 4.7 км. Т.е. оператора фонаря может быть не видно, а засвет на облаках, возможно, будет виден. Любопытно...
Старый 14.12.2012, 16:29   18
C055792
Аватар для C055792
Таблица расчета дальнобойности фонарей
Старый 14.12.2012, 16:43   19
6uka
Аватар для 6uka
Продам SR95 Intimidator 370$
Старый 14.12.2012, 16:46   20
6uka, поздно... теперь есть игрушка поинтереснее
Время генерации страницы 0.17167 секунды с 16 запросами
