Вернуться   Форум FONAREVKA.RU Фонари (по типу) Сверхмощные и поисковые фонари
Просмотров в теме 15600   Ответов в теме 28   Подписчиков на тему 6   Добавили в закладки 1
Старый 06.12.2012, 04:24 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4331
Поблагодарили: 10698 раз(а) в 2546 сообщениях
По умолчанию Новый фонарик на 12x XM-L
13000 Lumen 12 x T6 CREE XML XM-L Flashlight Torch, 3× 18650 Battery, 1x Charger
The brightest flashlight
Note: Please use good quality 18650, 26650 rechargeable battery with protection
This flashlight is high power LED flashlight with 12 x T6 LED bulb, when you use it, please don't see it directly by you eyes, don't use it long time in high power mode, please use good quality 18650 rechargeable battery, some cheap quality battery is not compatible with it, voltage is not stable, only can be used with 1 x T6 flashlight,
Features:
1. This torch is made by 12pcs CREE XM-L T6 LED, producing very bright beam of light(13000 lumens).
2. This flashlight uses a smooth reflector.The smooth reflector provides a more concentrated beam, and therefore a better throw (range)
3. The body of this flashlight is built of high quality aluminum alloy, and it has a very solid construction.
4. Internal wiring applies the high efficient booster circuit, and can utilize the batteries in the largest extent.
5. Crenelated Strike Bezel provides enhanced self-defense capability.
6. Excellent waterproof, suitable for outdoor environment, adverse weather conditions. (Don't use it under water)
Spec:
* Emitter Type: CREE XM-LT6
* Brightness/Lumens: 13000 Lumens max brightness
* Power: 45W
* LED:12 x CREE XM-L T6
* Light Color: White
* Lightbulb/LED Lifespan: 10,000 hours
* Modes: 5
* Mode Arrangement: Hi > Mid >Low > Strobe >SOS
* Lighting Distance: 1500m
* Battery Configuration: 3x 18650/3x26650 Batteries
* Input Voltage:8.4-12.6V
* Runtime: About 0.5 - 2 hours (based on quality of battery and the mode you choose)
* Switch Type: Clicky/Clickie
* Switch Location: Tail-cap
* Lens: Coated Glass Lens
* Reflector: Aluminum Smooth/SMO Reflector
* Material: Aluminum Alloy
* Color: Black
* Dimensions(L x Head Dia. x Body Dia.): 12.6 x 2.95 x 1.51 inch / 32x 7.5 x 3.9 cm
* Weight: 672g /1.48lb
Package:
1 x 13000 Lumen 12 x CREE XM-L T6 Flashlight
3 x 18650 Rechargeable battery
1 x 18650 Charger
altur (06.12.2012), Ektomorf (06.12.2012), Rocklight (06.12.2012), zetroot (06.12.2012)
Старый 06.12.2012, 04:39   2
Ektomorf
Сказал(а) спасибо: 157
По умолчанию Re: Новый фонарик на 12x XM-L
Видимо китайцы тоже читают Фонаревку и прочитали тему Lux-RC про рост эффективности при использовании 12 диодов вместо одного
Люменов много не бывает
Ektomorf вне форума   Ответить с цитированием Вверх
Старый 06.12.2012, 04:42 Автор темы   3
Admin
Администратор
Аватар для Admin
Стоимость $255
Старый 06.12.2012, 04:43   4
Maksym
Сказал(а) спасибо: 431
И используя более эффективные светодиоды получили вдвое бОльшую яркость за на порядок меньше денег... единственное что не учли охлаждение раз и вряд ли у этого фонаря вменяемый пучек для такого к-ва света - два. И, эта, кнопочка не расплавится-то? Это тры .
О! Так в цену помимо зарядки входят даже аккумуляторы! Plug and Play!
Старый 06.12.2012, 05:39   5
zetroot
Последняя активность: 16.04.2022 20:55
Сказал(а) спасибо: 131
Поблагодарили: 107 раз(а) в 61 сообщениях
Взять чтоли в качестве подарка на НГ себе?
13клм там нет конечно, но 10клм должно быть. И сразу 12 хмелей u3. Только бы хороший тинт найти.
zetroot вне форума   Ответить с цитированием Вверх
Старый 06.12.2012, 05:51   6
zetroot
Admin, слющай, адрес главной ебея я и так знаю, да, дарагой? Ссылочку поправь!
Старый 06.12.2012, 06:02   7
Rocklight
Аватар для Rocklight
Сказал(а) спасибо: 1116
какая то странная архитектура рефлектора, можно было эффективней расположить диоды. Такое ощущение что китайцы уже празднуют НГ!
Старый 06.12.2012, 06:03 Автор темы   8
Admin
Администратор
Аватар для Admin
zetroot, готово
Старый 06.12.2012, 06:05   9
zetroot
Интересно увидеть бимшот. Если верить ощущениям, то это получится что то среднее. Хотя в дали ничего не разглядеть - пересвеченый пол под ногами все убьет.
Старый 06.12.2012, 06:07 Автор темы   10
Admin
Администратор
Аватар для Admin
А это от 4sevens
ID:	63080 Нажмите на изображение для увеличения
Старый 06.12.2012, 06:09   11
zetroot
А сзади испаритель для фреона
Старый 06.12.2012, 06:45   12
awl
Аватар для awl
Сказал(а) спасибо: 208
Мда. 12 XM-L и всё ещё 3х18650, по 12А на каждый, типа..
Старый 06.12.2012, 07:26   13
ssr
Аватар для ssr
Сказал(а) спасибо: 80
им бы еще 6 хмелей в пустые места рефлектора добавить, а то корявый
Старый 06.12.2012, 07:34   14
Сказал(а) спасибо: 6723
Поблагодарили: 36291 раз(а) в 16769 сообщениях
* Power: 45W
не смешно даже
*Runtime: About 0.5 - 2 hours
исходя из рантайма и напряжения питания мощность больше похоже на правду, чем количество люмен.
в общем все как обычно, люмены посчитали теоретически возможные с диода, а запитали как смогли. по 3-4вт на диод. итого около 6 килолюмен. с диодов.
Старый 06.12.2012, 09:42   15
MOHAPX
Аватар для MOHAPX
Сказал(а) спасибо: 1935
Старый 06.12.2012, 10:48   16
zetroot
Настанет день и мы будем плеваться на пятидеесятиваттные лейки на устаревших xml валяющиеся у касс ашанов по бросовой цене.
Старый 06.12.2012, 11:20   17
Алексей063rus
Сказал(а) спасибо: 414
вот тут по 115 баксов почему то
http://www.ebay.com/itm/130...
а тут по 195
ta20 >tk21 u2 > tn11
i1,king T6 3C
L2T(L334 3-XP-G R4 4500K)
l2m(3-XP-C)
Старый 06.12.2012, 11:22   18
Алексей063rus
походу больше 100долларов хотят за батарейки и зарядник, потому что тут
- Support 2 kinds of Battery
- 3 x 18650 Rechargeable Battery (Not Included)
- 3 x 26650 Rechargeable Battery (Not Included)
Старый 07.12.2012, 01:31   19
alpg88
Аватар для alpg88
Сказал(а) спасибо: 472
потребитель помешан на люменах и мегапикселях. вот китай и удовлетворяет, заливными лейками и отвратными камерами на 20мп.
где смайлик отрыжка.
Старый 07.12.2012, 01:36   20
Maksym
Пипл хавает. Грех не воспользоваться... А объяснить что дешево много и качественно одновременно не бывает порой очень сложно.
Время генерации страницы 0.14417 секунды с 16 запросами
