5630
Администратор
Сказал(а) спасибо: 4330
COCOA, Flo. --(Ammoland.com)- Kel-Tec CNC, Inc., known for bringing innovative and unique firearms to the market, is pleased to introduce their latest product, the Kel-Tec CL-43 flashlight.
The Kel-Tec CL-43 is an extremely bright flashlight designed to be used in conjunction with a firearm. The CL-43 is CNC machined from extruded 6061 aluminum. The light operates via a rearward-click button located midpoint of the flashlight with both constant and momentary-on capabilities. The exterior features our patented nonslip pattern common with our firearms. Surfaces are either hard-coat anodized or Cerakoted. Five colors are available: Tactical: Black, OD green and Desert tan. Safety: Orange and yellow. Unique features of the CL-43 include: - Superior ergonomics due to the forward facing push button switch. - Small size. Can be enclosed by one hand and operated in parallel with a handgun. - Extreme light power. 420 lumens and an optimum beam angle. The CL-43 operates on three CR123 Lithium batteries and features Cree XP-G LED. Its weight with batteries is 107 g (3.8oz), and size is 24x38x102 mm (.94×1.5×4”). (Height x width x length). The switch is operated like the trigger on a gun, pointing the light as an extension of your arm. Compared to a light mounted to a pistol, the CL-43 has much superior range, and also keeps the ability to hold the light off the line of sight to conceal your position. The small size of the CL-43 makes it possible to hold and operate parallel with a handgun without impairing a conventional two handed hold. If required, and with some training, the light can be operated one-handed together with the gun. With the addition of a separate attachment, the CL-43 can also be mounted to a MIL-Spec Picatinny. An integrated belt clip and lanyard ring add to the versatility of the system. With a separate adaptor, standard AA batteries can be utilized, however, at an increase in length of the system. The powerful CL-420 LED Module is also used in our CL-42 conventional flashlight and the KSG Tactical Shotgun. CL-43 MSRP: $140.00 CL-42 MSRP: $ 80.00 As with all KEL-TEC products the CL-43 is designed, developed and manufactured in the United States. Patents Pending. To learn more about Kel-Tec CNC, visit www.keltecweapons.com. |
Шурик с шуриком
порнуха какая-то
еще бы его между скобой и спуском поместили |
Регистрация: 07.04.2011 Последняя активность: 05.07.2019 16:52
Сказал(а) спасибо: 25
Где-то я что-то такое уже видел...
Регистрация: 20.12.2010 Последняя активность: 06.08.2021 22:03
Сказал(а) спасибо: 204
При наличии рельсы под стволом странно выглядит фонарь сбоку.
Лично мне так неудобно было бы пистолет держать, там как раз место для левой руки. |
МеДВАдь
Видишь свет в конце туннеля!? |
Admin (22.11.2012)
Администратор
ДВА, я освоил публикации свежих новостей, как эта
. Впервые новость появилась в Интернете November 19, 2012 на известном сайте ammoland.com. Если есть данные более ранних публикаций именно данной новости - пруф в студию, для полноты информации будет полезно.
Администратор
Сказал(а) спасибо: 472
несущий свет в массы
Регистрация: 11.05.2011 Последняя активность: 20.09.2016 00:48
Сказал(а) спасибо: 137
Поблагодарили: 580 раз(а) в 125 сообщениях
практически все что делает келтек-парнуха-падделка пластмассовая
так что не удивила эта новинка-все в лучших традициях бренда....
★★★★★★★ Больше обзоров тут ★★★★★★★ |
asket32420 (22.11.2012)
