4766
Администратор
Сказал(а) спасибо: 4330
Компания CRELANT объявила о специальном рождественском выпуске новой модели CRELANT 7G6CS.
Specifications - CREE XM-L U3 bin LED with 50 000 hour life span. - Maximum output: 715 lumen - High efficient constant current circuit and output-luminance - Micro controller drive circuit - Tactical High Mode, and On side switch Infinitely variable brightness system - Hidden Strobe and SOS, Quickly click 2 times side switch ---> Strobe , and quickly click 2 times again ---> SOS - Working voltage: 2.7V--8.5VDC - Battery Types Supported: 1 x 18650 or 2 X CR123A - Runtime: High output at 2.6A: 715lumen max for 95minutes. Low output at 0.01A: 1 lumen max for 128 hours - Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy - Color: Black - Ergonomic grip with anti-roll design - Tactical forward tail cap switch - Bezel: stainless steel - High performance aluminum smooth reflector with concentrated beam shot - Waterproof: IPX-8 Standard - Lens: Toughened ultra-clear coated and anti-abrasion glass - Dimensions: Length 173mm, Head Diameter 48mm ,body 25.4mm - Weight: 182g excluding battery - Accessories: Lanyard, spare o-ring Features - Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search& Rescue and Outdoorsman - Tactical-on side switch Infinite brightness accessible - Stainless steel retaining ring on the bezel protects the head from drops and impacts. - CREE XM-L LED - Max output of up to 715 lumens with an effective range of 400 meters - New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability - Newly designed high efficiency broad voltage drive circuit - IPX-8 standard waterproof |
| Поблагодарили: 2 раз(а) |
havoc (23.11.2012), Tankist_20 (25.11.2012)
любитель
Регистрация: 14.03.2011 Последняя активность: 19.10.2025 00:55
Сказал(а) спасибо: 31
Поблагодарили: 74 раз(а) в 25 сообщениях
вызывает рождественское настроение, Санту и красные грузовики?
Ну вот! Опять хотелка!
Регистрация: 01.12.2011 Последняя активность: 17.04.2023 12:44
Поблагодарили: 19 раз(а) в 11 сообщениях
Может кому интересно, как работает эта самая "On side switch Infinitely variable brightness system", тот вот видео-обзор фонаря CRELANT 7G5CS с такой-же системой. Для нетерпеливых - смотреть с 9:00
