Просмотров в теме 4819   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 12.11.2012, 23:39 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Intl-outdoor NCR18650B 3400mAh (Black)
Official specifications:
  • Panasonic 18650 Protected Battery
  • Protected against Overdischarge, Overcharge and Short-circuit
  • Capacity: 3400mAh
  • Recommended Max Discharge: 6.8A (2C)
  • Full charge: 4.2V
  • Nominal voltage: 3.6V
  • Cut-off: 2.5V
  • Size: 68.9mm (length) * 18.5mm (diameter)
This is the latest cells from Panasonic with the highest capacity.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Very nice tracking between the two batteries and these batteries are good at both low and higher current.
Conclusion
This battery has higher capacity and better high current capacity than its predecessor (3100mAh/NCR18650A).
With the added protection it is a very good battery.
Notes and links
The batteries was supplied by intl-outdoor for review.
Admin (13.11.2012), Peli (13.11.2012), Qwertus (13.11.2012), Scratch (13.11.2012), ssn (13.11.2012)
Время генерации страницы 0.12070 секунды с 15 запросами
