Просмотров в теме 8509   Ответов в теме 13   Подписчиков на тему 2   Добавили в закладки 0
Старый 01.11.2012, 13:50 Автор темы   1
Последняя активность: 24.09.2019 12:00
По умолчанию Сгорел драйвер на SKYRAY 3T6
Здравствуйте!
Прошу помощи, сгорел драйвер на SKYRAY 3T6, сгорел героически, во время работы. Как понимаю, коротнул, ибо пружины - разогрело до отпуска. Все остальное - целое.
Выбираю драйвер, и не знаю, насколько подойдут следующие:
(попытка разместить ссылки, но увы, недостоин)
Собственно, речь идет о
раз
два
три
Подробнее:
1. 6-18V 3000mA 3-Mode Circuit Board for XM-LT60 Emitters (- Current: 3000mA
- Voltage: 6-18V
- 3-Modes: high, low, fast strobe
- Designed for XM-LT60 emitters)
2. 4-Mode 2500mA LED Driver Circuit Board for Flashlight (DC 5.0~8.4V)
- Model: DL-004
- Voltage: DC 5.0~8.4V
- Mode: 100%/50%/25%/SOS
- Current: 2500mA
- Diameter: 26mm
- Thickness: 1.6mm
- Great for DIY project or repair your flashlight
3. Boost/Buck 3-18V 5 Modes 24mm 30W Circuit Board
This circuit comes with low voltage protection at 5.7V, so please use two or more li-ion for best result.
Input Voltage: 3-18V (recommend use of 2-4pcs 4.2V 18650 or 4-6pcs 3V CR123A)
Output current (single LED): 5A
Output current (3 or 4 XM-L LED wired in serial): 3A
Modes: High - Medium - Low - Strobe - SOS (cycle) (with Memory feature), shut off to cycle to next mode
Low voltage Protection: When using single or two Li-ion batteries, input voltage becomes 5.7V, LED will flash twice per 3 seconds and then turn off after 3 minutes.
Over-heat Protection: When internal temperature becomes too hot, driver will automatically ramp down its brightness, make sure you "heat-sinked" the driver.
LED power output: single LED (8-10W), three or four LED wired in serial (25-30W)
Input requirement: Input current is about 3-3.5A, make sure the wiring and switch is capable of handling this type of high current.
*When driving 3 or 4 XML (serial) with 1-2 li-ion (serial), this circuit acts as boost circuit. When using 3-4 lion wired in serial, this circuit becomes a buck and temperature regulated circuit.
Dimensions:
Battery board measures 26mm
Main driver measures 24mm
Total heigh measures 17mm
Кто разбирается, подскажите, что выбрать, или - предложите свой вариант.
Спасибо!
[Исправлено: Piter, 01.11.2012 в 14:35]
Piter вне форума   Ответить с цитированием Вверх
Старый 01.11.2012, 14:04   2
xpm
Аватар для xpm
Сказал(а) спасибо: 31
По умолчанию Re: Сгорел драйвер на SKYRAY 3T6
xpm вне форума   Ответить с цитированием Вверх
Piter (01.11.2012)
Старый 01.11.2012, 14:06   3
Последняя активность: Вчера 21:08
Сказал(а) спасибо: 6718
Поблагодарили: 36262 раз(а) в 16756 сообщениях
(невнимательность)
Старый 01.11.2012, 14:12   4
Посмотреть сообщение Сообщение от Piter :
такой?
выбор небогатый:
кайдо 3 и 5 режимов соотвественно
http://www.kaidomain.com/pr...
это если диаметр контактной платы 26 мм
Piter (01.11.2012)
Старый 01.11.2012, 14:29 Автор темы   5
Piter
такой?
выбор небогатый:
Да, именно он, спасибо!
Старый 01.11.2012, 14:32 Автор темы   6
Piter
Посмотреть сообщение Сообщение от xpm :
Ок, понял, спасибо!
Старый 01.11.2012, 15:17   7
Да, именно он
не поделишься впечатлениями - фотками, как работает? прикольно копирует внешним видом катапульт.
Старый 01.11.2012, 15:32 Автор темы   8
Piter
Увы, не могу, могу поделиться ныне - только фоткой разобранной тушки
Он, собственно, был куплен в подарок, одариваемый пищал от восторга, восторженное пищание оборвалось спустя 3 месяца поюза. Надеюсь, скоро возобновиться
Старый 01.11.2012, 16:27   9
MA57
Аватар для MA57
Последняя активность: Вчера 07:59
Сказал(а) спасибо: 1135
Еще
раз: http://www.intl-outdoor.com... - судя по всему, тот же, что и на КД
два: http://www.intl-outdoor.com...
Hello there
Старый 01.11.2012, 16:36 Автор темы   10
Piter
Еще
да, спасибо, наблюдал и их, но - оба - распроданы.
Старый 01.11.2012, 17:26   11
kruvas
Аватар для kruvas
Последняя активность: 13.05.2014 18:58
Сказал(а) спасибо: 324
такой?
а где с такой башкой продаются? я вроде не видел таких
на fancyflashlights, откуда картинка - тоже не вижу
kruvas вне форума   Ответить с цитированием Вверх
Старый 01.11.2012, 17:30 Автор темы   12
Piter
Посмотреть сообщение Сообщение от kruvas :
Нет, башка - ровная - отсюда
На Али есть неровнобошкие например
[Исправлено: Piter, 01.11.2012 в 17:33]
kruvas (01.11.2012)
Старый 01.11.2012, 17:34   13
kruvas (01.11.2012)
Старый 01.11.2012, 17:48   14
kruvas
Аватар для kruvas
спасибо. буду иметь в виду что на их сайте поиск не очень добрый, что странно для магазина )
искал "skyray", "sky-ray", "3t6" и один фиг.
а надо было "sky ray"
Время генерации страницы 0.12982 секунды с 15 запросами
