Просмотров в теме 4177   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 15.10.2012, 20:33 Автор темы   1
Сказал(а) спасибо: 25
По умолчанию Messenger - коногонка с пейджером.
Messenger RT cap lamp is a robust, simple two-way text messaging device from Northern Light Technologies® (NLT) that provides powerful real time communication in a convenient and intuitive package. The 433 receiver embedded in the unit allows the lamp to be tracked by placing NLT active RFID tags in key locations; this tag information is then sent to the server by the lamp via the Wi-Fi network. Free text messages (up to 60 characters) are sent via the Wi-Fi network through Northern Light Technologies’ Digital Mine Software and received by the cap lamp user within seconds.
A brief flashing sequence on the LED cap lamp alerts the miner a message has been received, with the duration and persistence of the flash indicating the priority level of the communication. The miner uses a toggle switch to read the message, which is scrolled across the LCD display, and uses the same toggle to send an appropriate response from 40 predetermined messages. Multiple replies can be sent in response to the same message, with each response uniquely logged and time-stamped on the server, creating real-time updates as underground circumstances change. The tracking accuracy that the Messenger RT provides is unparallel in the mining industry, opening up endless productivity and safety opportunities for your operation.
Wi-Fi
• Standard: IEEE 802.11 b/g
• Frequency Range: 2.412-2.484 GHz
• Data Rate: b: 11MB b/s g: 54MB b/s
• Transmit Output Power: 14 dBm + 1.5dBm/-1.0 dBm
• Security: WEP 34/128, WPA-PSK, TKIP, AES, end-to-end encryption
Battery
• Type: 15 Cell NiMH, 6 Volts
• Charge Time: <12 hours
• Discharge: >12 hours
• Charger: “E” type Northern Light®
Headpiece
Primary: 1 Watt LED
Primary Lifespan: Minimum 10,000 hours
LUX: 3,000
General
Display: Backlit 2-line LCD
User Input: Toggle Switch
Weight: 1.6 kg or 3.4 lbs
Reverse Tracking Receiver: 433 MHz
http://www.nltinc.com/cap-l...
Admin (15.10.2012)
Время генерации страницы 0.07302 секунды с 15 запросами
