4009
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Battery test/review summary for small batteries
The full comparison can be found on my website. ![]() Doing my large 18650 battery test I also got some smaller batteries. I started with publishing individual reviews and has now enough batteries to make a full comparison of them. This comparison will mostly include 10440, 14500, 16340 and 18350, but if other LiIon batteries in the same capacity range show up I will probably also include them in this comparison. I do not plan to do many updates to the text of this article, but because the charts are fetched from my server they will be updated frequently. All the batteries I have tested will be included, and sometimes also for unpublished test/reviews that might be only partial done, these reviews will be published later when they are finished. This does also explain why a battery can be present in some charts, but not in other. Because the charts will be updated I will not comment on how different batteries compares to each other in this article, that might not be valid after the next update of the charts. Note: The picture above does show the batteries I have tested when publishing this article, more batteries will be added to the test, but the picture will not be updated. Battery charts ![]() The first chart is the capacity at different current draw. To measure this capacity I have discharged the batteries down to 2.8 volt at the specified current rates (The 3A discharge is mostly done on IMR batteries). ![]() Some lights cannot drain the battery down to 2.8 volt, but need considerable more voltage, especially to get full brightness. In the above chart I have measured the capacity drained when the battery is down to 3.6 volt, again at different current. Batteries that has a lot of capacity when measured to 2.8 volt does not necessary have that when measured to 3.6 volt, especially at high current drains. ![]() This curve shows how the battery voltage changes when capacity is used from the battery, this curve is made with a 1A current draw. The 1A bar in the above bar charts are based on this curve. ![]() Instead of showing the capacity of the battery, it is also possible to show how long time the battery will last at the 1A current draw. ![]() The batteries has a specified current, this current is the recommended maximum drain on the cell. If this specification is missing, it can usual be assumed to be 2xC, i.e. a 2400mAh battery will have a specified current of 4800mA or 4.8 Ampere. These assumed values are not shown in the chart. Batteries with a PCB protection also has a trip current, this is at a higher value than the specified current. In my opinion 30% up to 50% above the specified current is best. The "Protection trip" will be missing for unprotected batteries and because my test equipment is configured to starts at 1 ampere batteries with "Protection trip" below 1 ampere will also be missing. ![]() The 10440/14500/16340/18350 specifications defines the size of the battery, but protected batteries are longer, because a protection circuit must be added and sometimes there is also added a button top. Not all chargers and lights can take the longest cells.
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 5 раз(а) |
blasph3m3r (16.09.2012), combat_rabbit (15.09.2012), MOHAPX (15.09.2012), PLAY (16.09.2012), Алексей063rus (15.09.2012)
