Просмотров в теме 3166   Ответов в теме 1   Подписчиков на тему 1   Добавили в закладки 0
Старый 04.09.2012, 22:24 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of EnerPower+ 18650 2250mAh (Blue)
Official specifications:
  • Nominal Voltage: 3.6V
  • Capacity: 2250mAh
  • Minimum Capacity: 2150mAh
  • Standard charging current: 450 mA for 5.5 hours to 4.2 V / 0.2 C
  • Maximum charge current 0.5 C/1200 mA
  • Protection: 7A
  • Deep discharge protection: at 3V
  • Nickel base plate for added durability
  • Diameter: 18.5 mm + / - 0.01
  • Length: 67.8 mm + / - 0.01
  • Weight: 46g
This is a high current battery with protection.
The battery has no problem delivering 7A, but the protection does reduce the output voltage, compared to unprotected batteries.
Conclusion
Adding protection to the cell, makes it easier and safer to use it, but performance is lower than unprotected cells.
The battery is a very good battery.
Notes and links
The batteries was supplied by ENERDan for review.
Admin (04.09.2012), MOHAPX (04.09.2012)
Старый 04.09.2012, 23:32   2
MOHAPX
Аватар для MOHAPX
Сказал(а) спасибо: 1935
По умолчанию Re: Test/Review of EnerPower+ 18650 2250mAh (Blue)
Время генерации страницы 0.08043 секунды с 15 запросами
