3386
Регистрация: 25.06.2010 Последняя активность: 23.08.2013 16:00
Поблагодарили: 104 раз(а) в 43 сообщениях
For the past few years, the XTAR TZ20 has served as the "entry-level" model in XTAR's Tactical series. It has received continual subtle styling and emitter updates with the most recent in the form of an XM-L U2 for the latter.
Is this enough to keep this stalwart tactical light relevant 2.5 years after its initial launch? We shall find out. MFG SPECS MSRP: $47.99 USD 50,000 hours lifespan Cree XM-L U2 LED Max output 820 lumens Max Duration: 18Lm/180 hours (Tested by 1x 2200mAh 18650 battery) OP textured reflector, throws beam over 175 meters Constant current circuit - maintains constant brightness Powered by 1 x 17670/18650/18700 140.5mm (Length) x 25.0mm (Diameter) x 35.0mm (Head) 125-gram weight Made of durable aircraft-grade aluminum Toughened ultra-clear glass lens with anti-reflective coating Premium Type III hard-anodized anti-abrasive finish Waterproof to IPX-8 Tactical tailcap switch with memory function Anti-roll, slip-resistant body design Creative design, with 5 Low10%, Mid40%, High100%, Strobe, SOS mode, can cancel or recover Mid, Low, Strobe, SOS mode at will. Accessories included: Lanyard; holster; Body clip; standby Tactical ring; Two spare O ring circle PACKAGING / CONTENTS The TZ20 I received came in a rather unassuming generic XTAR branded box: ![]() This is unlike what is shown on XTAR's site (which features a presentation case) [NEW 6/26: Additional items included were a wrist strap and spares for the tail cap cover, switch and 1 x o-ring: ]CONDENSED VIDEO SUMMARY Here is a quick high-level video summary of the TZ20 while I work on fleshing out this review: [video=youtube;tyWoBxboi-M]https://www.youtube.com/watch?v=tyWoBxboi-M[/video] DESIGN / FEATURES The TZ20 features a crenellated bezel but just not of SS and comprises about a thrid of the upper portion of the head. It allows one to easily see if the light is on when stood bezel down: ![]() The double-coated AR lens sits recessed enough to be protected from most scratches. There are rectangular grooves that provides both aesthetics and some grip (albeit not much) during removal. The head can be completely disassembled as follows: ![]() The lens looks like it can also be removed but I didn't try. The reflector is ultra smooth with no discernable imperfections (beyond the circular machinining). While there is a black plastic mold around the LED, there isn't a ledge to center the reflector so it does need to be done manually: There are six "shovel-head" shaped grooves that serves as the main design elements on the head with a few cooling fins right aft of that which help dissipate heat but given it's moderately driven, doesn't really get all that hot (see Runtime section for full details): The tube features two flat sides that bear XTAR’s name and on one and the model on the other The rectangular shaped texture doesn't really contribute much in the way of grip: Rather the placement of one's hand between the tactical ring and cooling fins serve that purpose better. In my video, I had mentioned the clip was awkwardly positioned and stuck too far off the body but in mfg pics, I noticed the clip was bent so that the curve touches the body. Upon removing the tactical ring (which doesn't require the removal of the o-ring, nice!), I noticed the clip is easily removable: ![]() Once off, I bent it so now it touches the body as well. This should provide additional grip when it's clipped. Another thoughtful touch is that there is a groove that holds the clip solidy in place so that it doesn't rotate. There is an additional attachment point on the clip that can be used with the included wrist strap: ![]() The tailcap features the same rectangular texture on the body. There are three crenellated points that can be used for strike, glass breakage and tailstanding purposes: The forward clicky allows momentary and is used to cycle up to three (programmable) output levels and two blinkie modes (more details in UI section). The threads on the head are trapezoidal cut while the ones on the tail are square-cut thus the tube can't be reversed around: Given neither end is anodized, the TZ20 can not be locked out. I had no issues w/either my shortest cell (AW IMR 1600 @ 65.2mm) or longest (XTAR 18700 @ 69.2mm): ![]() There is a spring in the tailcap end and while absent on the the head there is a raised nodule that allows the use of flat top cells: SIZE & HANDLING ![]() | XENO S3A | Sunwayman T20C | XENO G10v2 |XTAR TZ20 | ThruNite TN10 | FoxFury Rook CheckMate | Fenix TK21 | ThruNite TN11 | ThruNite TN11S | Crelant V9-T6 It fits quite nicely in my medium-sized hand: FIT & FINISH The overall fit and finish is quite good. The anodizing matches between all the parts: ![]() Short of the one on the head, the laser engraving is fairly sharp with no blotchiness: There were some minor spots of ano missing but they look more to be from mishandling rather than misapplication. Also while there was some grease applied, it was in minute quantities and none were found on the o-ring. Also, as mentioned in my video, given its tactical-use aspirations, the crenellated tail cap may not be the best choice as it can potentially hamper operation of the switch. Also, the o-ring in the tailcap side might just be slightly thick as I've had a really hard time while unscrewing the tailcap after it has sat around for a while. This is after I've already applied ample grease on it. Beyond this, the TZ20 feels solidly put together with no other real shortcomings. UI Now we get to the part that truly defines this light. XTAR has created a DIY interface so that one can custom tailor the modes to their liking by soldering the two contact points in one of four columns: ![]() I normally don't bother mentioning the instruction manual for lights I review but XTAR really deserves kudos for the TZ20's manual. It spans 8 pages of which two are dedciated to the "DIY" aspect of the TZ20. I've taken pics of this until I can recreate the matrix: [pic] More to come... BEAMSHOTS Indoors (5m) High ![]() ![]() Med ![]() Low ![]() For details of the above indoor shots and comparo vs. many other lights, please check Epic Indoor Shots Trilogy Whitewall Hunting Exposure settings in sequential reading-order from top left: 1/25, 1/100, 1/800, 1/1600 @ f2.9 on AWB (light is ~.4m to wall / camera ~.59m): ![]() ![]() ![]() ![]() RUNTIME The relevant battery stats are provided above each runtime graph along with: - Voltage of the battery at the start and end of the test - Current draw as taken right before the test - Actual runtime using ANSI FL1 (first in HR and then in M so for the RL3100 on High, read this as 2.2hrs OR 132min) - NEW (as of May 2012): Lumens measured on PVC LMD @ 30 seconds - Also for High, captured the temperature: ambient, the head at start and the max it reached (fan was used for all bats) ![]() After an initial drop, the TZ20 runs semi-regulated for roughly 25min and then falls out of regulation with a steady decline in output. I haven't been able to match XTAR's claim of 800+ lumens and got 714 and 708 w/the AW2600 and RL3100 respectively after 30 seconds. It could be that I have a slightly underperforming sample. MORE TO COME... ======= Disclosure: TZ20 provided by md-lightsource for review. |
