2764
Регистрация: 02.06.2012 Последняя активность: 21.04.2015 12:00
Поблагодарили: 42 раз(а) в 22 сообщениях
UPDATE 6/27: Official stats, from a dealer's web site:
- Outstanding Tactical-on Side Switch Design - Unique Switching System with Low-voltage Indicator Lamp - Solid Structure, Reverse Battery Protection Circuit - Detachable Lanyard Ring, UNC1/4'-20 Camera Threaded Hole - Soft-contact Side Switch: Three modes constant output, hidden Strobe and SOS Three constant output modes: 190Lumens (1.5hrs) – 50Lumens (10hrs) – 3Lumens (50hrs) Sunwayman likes to rate output using primaries only, this light is capable of up to 500 lm when using 16340... (Standard cautions of running Turbo for short bursts only) Strobe: 190 lm to (500 lm) SOS Mode - Working voltage: 0.9~4.2V - Dimensions: 82mm (length) x 25mm (head diameter) - Weight: 63g (battery excluded) - Accessories: Clip, O-ring, lanyard, holster, stainless steel lanyard ring ---------------------- From a german forum, pics of the Sunwayman C10R with XM-L U2. Thanks to Eric242 for bringing this up in Sunwayman's marketplace sub-forum! Pics removed by moderator request. You can see them by following this link: http://www.messerforum.net/... Side switch and battery indicator look like those on the T20CS. Plus, a tripod attachment point, very cool. And it looks tiny. Stats (according to the pictures): -XM-L U2 emitter -1xCR123 or 1x16340 battery -Low: ? -High: 210 lumens for ? hrs (? with a 16340) -Drop resistant to 2m -IPX-8 to water resistant to 2m -"smart" side switch -Low voltage indicator -Tripod attachment point -Accessories: lanyard, holster, spare o-rings -Dimensions: sorter and fatter than the V11R -Smooth reflector -Stainless steel bezel |
